01 Maxima AC not very cold
Old Jun 27, 2014 | 01:54 PM
Trin1j23's Avatar
My AC isn't very cold and I have it on fill blast. It takes a long time to get cold. I checked the freon pressure and it's good. My cousin has the same car and his AC is a lot colder.
Old Jun 28, 2014 | 11:36 AM
WTF?'s Avatar
Make sure that the pressure isn't too high. I recently went through my a/c and I charged it to the max recommended pressure, and it didn't blow very cold, because the compressor kept cycling on and offbecause it was cycling the high pressure switch. I just pushed the Schrader valve and let a little out, and it got considerable colder. Good luck.
Old Jun 30, 2014 | 04:57 PM
TTYME's Avatar
Thanks WTF, I'm having the same issue. I'll try this after work.
Old Jul 1, 2014 | 01:57 PM
homeyclaus's Avatar
If the AC system in the cars is of the automatic type where you set the temperature - the system depends on three temp sensors to work properly. The FSM has the procedure for kicking the AC panel into diagnostic mode, and it'll tell you what the temp sensor reads are and has a troubleshooting procedure for each. Usually when the temp sensors code, they fail open, so the temp will read 99.9. Mine did, but the result was the warm temp never blew very warm.
Old Jul 5, 2014 | 11:18 AM
crazy97's Avatar
I just went through this also. The shop filled it to max capacity which was too much. The question is how much should I let out? Supposed to be 90 tomorrow, so we'll see if its still cold.
Lakersallday24
Nov 7, 2024 07:31 PM
cheftoo
Aug 20, 2015 05:17 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
