Front end thump
Old Jun 29, 2014 | 02:22 PM
Legacyrisk's Avatar
Front end thump
I have a thump like a skip when I accelerate from a stop with the wheel cranked as well as during heavy braking. I've replaced the cv/axels I know it needs struts would old struts cause this ? Any ideas ?
Old Jun 29, 2014 | 02:30 PM
a33_ridah's Avatar
commonly discussed issue..with the 5th gen.
likely culprits include
*motor mounts (typically the passenger side causing most notable noises)
*bad wheel bearings
*loose strut tower bolt OR worn rubber bushing the nut sits on
*worn end link bushings.
If you search you will be able to find common "tests" to rule certain things out.
report back. I have a similar issue on a maxima i just bought few days ago.
Old Jun 30, 2014 | 04:58 PM
Legacyrisk's Avatar
Thx
Ill take a look I live in phoenix dessert so bushings bearings and well anything rubber will collapse in this heat ill start with your suggestions
*bad wheel bearings
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
