p0171 - 2001 maxima
It has a brand new supposedly OEM Hitachi Throttle body with a cheap sticker that says "made in japan - abv0039"
http://www.ebay.com/itm/Idle-Air-Control-Valve-HITACHI-ABV0039-fits-00-01-Infiniti-I30-3-0L-V6-/400699382892?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d4b8b5c6c&vxp=mtr
If the NEW OEM MAF doesn't work.. I'm going to buy an OEM IACV from the dealer....something looks funny about this "OEM Hitachi" iacv..will keep updating this post as I try these things.
So far:
1) Changed catalytic converter + a new 02 sensor (cat code went away..p0171 still there)
2) Swapped in a good oem maf from another car....code still pops up (no code on the other car though)
3) Double/Triple checked all lines and hoses...
will do
1) Try a new OEM maf
2) Try a new OEM IACV directly from the dealer.
So far:
will do
Problem solved..It was the upper intake manifold gasket. Gasket was flattened and a part was being sucked in. I sprayed carb cleaner around it a few times before with no results, however, I had a feeling to change it.
ah2002
Mar 9, 2016 01:42 PM
District
Aug 15, 2015 08:23 PM
kirkhilles
Aug 8, 2015 10:53 AM
