Collant dripping from IACV
Old Jul 4, 2014 | 08:25 AM
whivins's Avatar
Well my newly installed IACV has a small coolant leak. Drips every 15-20 seconds. I have read on this forum, that this can lead to shorting out the IACV. One thread I was reading recommended by-passing the coolant from the IACV entirely. Looks pretty easy to do. Is this a good procedure, or should I apply some gasket maker sealant to reseal unit? Thanks!
Old Jul 4, 2014 | 05:45 PM
Montego Murph's Avatar
Whether it's the "best" idea or not, I'd bypass that thing immediately, and discuss it later.
Old Jul 4, 2014 | 06:04 PM
Donkeypunch's Avatar
Is it leaking because it uses a gasket but you did not use one?
china quality?
Old Jul 4, 2014 | 07:47 PM
ManualMaxima's Avatar
5th Gen till she dies!
+1 get it done yesterday!
Old Jul 5, 2014 | 06:29 AM
whivins's Avatar
china quality?
I used the gasket that came with the OEM part. I removed and applied sealant and no leak this morning. Sounds like it's recommended to by-pass?
Old Jul 11, 2014 | 12:03 PM
FanaticMadMax's Avatar
why would you wanna bypass it? The point of coolant is to keep the IVAC cool, otherwise it'll get too hot and get fried since it is electronic part, especially engine heat and electronic will not bode well and will end up shorting out the electronic
Old Jul 11, 2014 | 12:11 PM
foodmanry's Avatar
Da Roller Coaster!
By-passing is added insurance in case there is coolant leakage which can result in a short of the IACV and fry your ECU. Which is worse? Having a throttle body and IACV that is a bit warm or frying your ECU?
You decide...this is why people by-pass the cooling.
Old Jul 11, 2014 | 03:51 PM
Coolant is used to warm the throttle body during COLD weather to prevent sticking, as far as I know.
Old Jul 11, 2014 | 04:26 PM
Fakie J Farkerton's Avatar
Old Jul 11, 2014 | 07:45 PM
cornholio's Avatar
this is what i've heard as well
Old Jul 11, 2014 | 09:24 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You're high.
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
ag90fox
Sep 9, 2015 12:22 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
nbstriker10
Sep 4, 2015 04:26 PM
