Best Brand for Control Arm?
Old Jul 17, 2014 | 09:18 AM
  #41
NmexMAX's Avatar
dot dot dot ...
^^ SOMETIMES pressing in new bushings into existing arms is more arduous than just replacing with a fresh arm.
All has to do with budget, requirements, time, priorities. Personal preferences prevail.
I had Es bushings and was going to do that route, didn't have the resources needed, sold the bushings and bought a set of new arms.
Old Jul 17, 2014 | 10:00 PM
  #42
Donkeypunch's Avatar
Another thing these cars are 14 years old
who knows really if the arm has been bent by a crazy pot hole.
Plus, it's only $69 for a brand new moog. Cheap!
Old Jul 18, 2014 | 09:00 AM
  #43
JDM_A33's Avatar
I have access to a press and a brush to clean the arm area before pressing the bushing in and a little lube will let it slide rite in.. Just wanted to now if there was better than that with buying the arm
Old Jul 18, 2014 | 10:03 AM
  #44
djfrestyl's Avatar
Suspension Yoda
^Nope, if the press work is easy, ES bushings and Moog ball joint is the best control arm you can have.
Old Jul 18, 2014 | 10:42 AM
  #45
cornholio's Avatar
Originally Posted by Donkeypunch
Which is bigger or smaller?
What brand?
Mine is oem and it wines just idling.
Something there needs replacing I hope it's just the line that's leaking.
btw, is it the banjo bolt that leaks or the actual line? At the crimp?
i bought edelmann (appears to be similar to gates if not the same)
my leak was near the top of the hose- i could just poke the insulation and fluid would drip out.
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
EdRomo86
Sep 12, 2015 07:49 PM
carid
Sep 9, 2015 05:06 AM
