Brake pedal
Old Aug 6, 2014 | 07:38 PM
Chris213's Avatar
Brake pedal
Changed my masters cylinder bled the brakes by procedure and it's still needs to travel a distance before the brakes catch. But when they do catch they brake normally is there any way to adjust the brake pedal??
Old Aug 6, 2014 | 07:43 PM
Fakie J Farkerton's Avatar
No.
It takes a long time bleeding to get all the air out after replacing the brakes master.
Did you bench bleed it?
Old Aug 6, 2014 | 09:04 PM
Chris213's Avatar
The master cylinder was bench bled
Old Aug 7, 2014 | 11:30 AM
FanaticMadMax's Avatar
Has the brake pads changed or was it the same? Since if you just replacing the master cylinder, there's not going to be a difference on your brake pedal travel with the same brake pads. In other words, the pads wears down, as it wear, the brake pedal travel will increase. Goes opposite of when new brake pads, it's thick as OEM specification. your brake pedal travel will be shorter. SO what was wrong with your master brake cylinder in the first place?
Old Aug 7, 2014 | 03:15 PM
Chris213's Avatar
The pedal was really soft and when the car was in the air you were able to still spin the tires with the brake pedal fully depressed. I haven't changed the pads but everyone who looks at them tells me there is still about 80% left even though they are making all kinds of noise. I'm not a mechanic so I dont know that much about brakes and stuff
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
