!! HELP with Pop Charger Install !!
Old Jan 22, 2002 | 12:09 PM
Empz's Avatar
Guys ... I need help.
I was trying to install a Generic Cone Intake.
And I can't seem to separate the MAF from the Throttle Body.
The Rubber Seal on the Throttle Body, doesn't seem to want to give ... I tried real hard and I can't separate the Two!!!!
Thanks,
Eric
Old Jan 22, 2002 | 04:12 PM
Empz's Avatar
C'mon guys ... any Suggestions????
Old Jan 22, 2002 | 04:20 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
MAF from the TB? You only need to separate it from the black air thingy. Use a flathead screwdriver and jam it between a gap... twist the screwdriver to loosen it.
Old Jan 22, 2002 | 04:24 PM
Garfield's Avatar
i had the same problem. ppl said that's easy to take it off...but not for me....
i left the MAF on it, just took the air box out...but took long time to unscrew those 4 nuts.
Good luck.....
Old Jan 22, 2002 | 04:38 PM
RussMaxManiac
Now your getting around to installing it!?
lol!
The MAF needs to be pulled out with the box for easier access to the bolts. The MAF slides into a rubber part that is inserted into the resonator that is between the maf and the throttle body. Big verticle black piece. It will come out, just wiggle it up and down and eventually it will pop out. Don't use any form of oil or grease on it. It won't stay on after you put that on when you try to tighten it back down. Just loosen the clamps as much as you can.
Old Jan 22, 2002 | 04:42 PM
ZIPPIN's Avatar
Mauja He Mauja
lol!
he knows,,,trust it,,work it,,believe it
MaxLife17
Jun 27, 2019 01:37 PM
Vequity
Sep 10, 2015 05:26 AM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
