Speedo problem
Old Aug 24, 2014 | 12:13 PM
frank5079's Avatar
Speedo problem
I've tried the search feature to no avail; I have an 01 Maxima SE automatic and the speedo reads half of the actual speed. I have replaced the vss behind the left tire and still have the same problem. Is the speedo in the instrument cluster the culprit?
Old Aug 24, 2014 | 04:10 PM
DennisMik's Avatar
Probably. Does the tachometer seem to be OK?
Go to page 117 in the service manual (link below) and do the self test. Observe where the needle points.
http://boredmder.com/FSMs/Nissan/Maxima/2001/EL.pdf
Old Aug 24, 2014 | 06:24 PM
BigLou55's Avatar
My 5th gen has a speed sensor separate from the vss behind the tire. The speedometer pinion if you have one will be on top of your tranny near the back of it. Test that as well.
frank5079's Avatar
Thanks, I'll give that a try....
Old Aug 27, 2014 | 07:23 AM
Itz Shak's Avatar
I have this EXACT problem.. Please keep us updated!
Old Sep 1, 2014 | 01:03 AM
Itz Shak's Avatar
Old Sep 1, 2014 | 05:27 AM
Bronxboi5's Avatar
ok since you have a auto... go on a cheap site and buy a speed sensor since yours is located on your tranny...... but aswell you have 4 abs/speed sensors on each hub... go to a shop that can test your abs and they shall tell you what sensor it is.... it's reading half the speed because one isn't reading proper.... not a hard fix at all... take off tire see to lines... 1 is brake line other smaller one is abs/speed sensor..... in screw with 10mm rachet and replace and plug the other in.... hardest part is taking off the tire
Old Sep 1, 2014 | 05:48 AM
QueensMAX's Avatar
Has the transmission been changed before? When I had my transmission changed a few years ago, the mechanic forgot to swap over the harness from the old trans. Some 00-01 maximas use the ABS sensor to generate the speed instead of a speed sensor on the transmission. In my case, both the speed sensor and and abs were in conflict with each other and the gauge was not reading the right speed.
Try unplugging the speed sensor on the transmission and see what happens.
Are you sure you changed the speed sensor and not the revolution sensor..The one right near the tire is the revolution sensor. The speed sensor is more behind the transmission and has a green wheel..
It looks like this:
http://www.am-autoparts.com/Nissan/M...32/688214.html
Old Sep 1, 2014 | 02:10 PM
Itz Shak's Avatar
It looks like this:
You're right, I only changed the revolution sensor.. http://www.ebay.com/itm/AT-Automatic...2a79d4&vxp=mtr
I'll buy that sensor and see how that project turns out.
Why does it say 16 inch wheels? Mines are 17 inches.
Old Oct 26, 2014 | 06:14 PM
frank5079's Avatar
Sorry for the delay guys but my speedo is now working!!! Turns out my car does not have a revolution sensor. The spot on the trans where the rev sensor would normally go was blocked off. As it turns out our master tech here at Infiniti was right after all, and that my problem with the speedo is that it gets its signal from both front anti-skid ABS sensors. So after replacing them both my speedo now works!!!
Old Oct 26, 2014 | 08:19 PM
Itz Shak's Avatar
Thanks for the update. So it was the abs wheel speed sensor? I kinda figured that after i found out my left front and right rear sensors were "open circuit". Glad to see your problem was fixed.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
