Floor Jack Points??
Old Nov 13, 2000 | 06:39 AM
Maximizd's Avatar
I wanted to remove my wheels to clean them this weekend. I was going to use a floor jack to life the car, but I was unsure where the best spot was on the car to do this. I ended up using the silly scissor jack to lift each section of the car up. Anyone know the right spot on the 2K for this?
Old Nov 13, 2000 | 06:46 AM
Shingles's Avatar
The missing moderator
Your owners manual does infact mention this.
But if you don't have one... the area where you use your sissor jack is wher eyou can use a standard jack and it's where you place the jack stands.
Old Nov 13, 2000 | 09:28 AM
mdeal's Avatar
How can you put a jackstand under it at the same point the floor jack is located?
Old Nov 13, 2000 | 09:54 AM
Shingles's Avatar
Well then use the front jack point and then use the floor jack.
If you read my message again, all it says is that the jack and the jack stands point are the same. Never said that you should jack it up there and use the stands there at the same time.
PLEASE read the owners manual... lots of useful information in there.
-Shing
Old Nov 13, 2000 | 11:03 AM
mdeal's Avatar
Shingles, I was only clarifying. Thanks for the info.
Old Nov 13, 2000 | 11:12 AM
Shingles's Avatar
ahh gotcha... sorry.
Old Nov 13, 2000 | 12:37 PM
DanNY's Avatar
Ad·min·is·tra·tor
if your worried about bending anything you can try lifting up by where the lower control arm connects to the frame. this tends to be a pretty strong area.
Dan
Old Nov 14, 2000 | 05:03 AM
Confused's Avatar
Permanent Maxima.org Resident
Sounds like a good way to paint your calipers
hint.... hint.
Old Nov 14, 2000 | 07:08 AM
PIONEER's Avatar
Any of U guys look at the picture on the jack itself that comes with the car? it tells U where to put the jack.
Oh another thing, Next time when you jack the car in the air, 1 tire, try to open the front door, the chassis is soo weak that it actually bends and the door and the door lock don't make full contact until U put the car back on the ground. Don't try to slam the door shut or U'll break the lock.
Old Nov 14, 2000 | 07:54 AM
Shingles's Avatar
This happens in just about every car that I've done this to. that why I really do'nt like jacking up the car from one corner only... I jack up the car fron the front so both sides are off the ground... to prevent what you are describing...
-Shing
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
