Can broken axle cause abs, traction, slip
Old Sep 30, 2014 | 05:41 AM
MTR's Avatar
MTR
To make a long story short I was driving to work yesterday and my abs, traction, and slip lights all illuminated at the same time. As this happened I starting hearing a grinding noise coming from the passenger rotor. I took the tire off only to find the axle nut as well as the threading had rusted out completely and snapped clean off the axle.
My question is can this cause the wheel speed sensor to go bad? If not what should I check to remedy the situation. After sitting for the day I started the car to see if the lights were still on. The abs and traction were still on however, the slip light turned off.
Old Sep 30, 2014 | 03:38 PM
george__'s Avatar
What year you own?
I have a 2002 that would ABS, SLIP and TRACTION usually when raining and it turned out to be either the rear right ABS sensor or the wire.
Old Sep 30, 2014 | 06:12 PM
MTR's Avatar
MTR
Its a 02 GLE
Old Sep 30, 2014 | 07:36 PM
george__'s Avatar
If OP is getting a new axle, get one with the damper thingy on it.
Old Oct 1, 2014 | 06:10 AM
MTR's Avatar
MTR
I'm buying one today, do you have any links for one? I was looking on Ebay and Rockauto but, I'm not sure which to get.
Old Oct 1, 2014 | 09:13 PM
george__'s Avatar
I can't help... My issue was broken CV boots due to being stupid and ended up going from aftermarket to original OEM axles because the car vibration was excessive with the aftermarket ones.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
