ECU swap, will it not start with out key reprog?
Old Oct 22, 2014 | 07:40 PM
cdoublejj's Avatar
if i swap my ECU will it not even start at all with out reprogramming the key? i'm just wanting to swap my ECU to see if that is the problem.
Old Oct 22, 2014 | 07:47 PM
nestorlugo's Avatar
Perhaps a locksmith can help!
Old Oct 22, 2014 | 09:27 PM
DennisMik's Avatar
The RFID code from the key is stored in the ECU, so you would have to get the keys reprogrammed.
Locksmiths will program the keys in their parking lot, so find a locksmith with the best price. The drive over there, take the connector off the original ECU. plug in the new ECU and have them re-program it. Make sure you have all you keys with you.
Old Oct 23, 2014 | 01:07 AM
cdoublejj's Avatar
is there a way to flash ECU with the RIFD as original?
I'm assuming based on your answers it will indeed NOT start.
as someone with ZERO money and income this could pricey fast.
Old Oct 23, 2014 | 05:29 AM
CS_AR's Avatar
To avoid playing a locksmith or dealer you can purchase Nissan Data Scan II, for roughly $62.00, then purchase a VAG COM OBDII 409.1 USB adaptor for around $15, and use a compatible PC to reprogram the codes.
I would not recommend this unless you are keeping your working ECU as a backup and you are looking for a way to experiment for less than $100 and you already have a PC (usually a laptop) that is running Windows 7 or older.
Purchasing the an incorrect or malfunctioning VAG cable can keep the product from working properly.
Here's a video on how it works below.
http://www.youtube.com/watch?v=SmQsR1rqUfA
Old Oct 23, 2014 | 05:48 AM
nestorlugo's Avatar
Good shyt CS_AR! I'm the type of person that will loose keys ,it cost me $150+ the first time and a lil over$100 the second i haven't lost them since but i this is a great alternative.
Old Oct 23, 2014 | 03:34 PM
cdoublejj's Avatar
i see. yeah i wanted to have 1 ECU as back up, i usually keep may spare parts in the trunk of the car. if i was ever to break down during a road trip or something it could be very handy.
this let me reprogram the keys but, not the ECU?
EDIT: i also have all kinds of laptops, i'm familiar with flashing firmwares and what not.
Old Oct 23, 2014 | 06:37 PM
CS_AR's Avatar
Check out the following thread about the master code value.
https://maxima.org/forums/all-motor/...-nvis-tip.html
You will need to read about the ICU. The following page provides information about the ICU and the master code. The page is in spanish. Chrome will translate if you need it.
http://www.cerrajeria.com.mx/inmo/PINcode.html
You will need to read the NDS2 manual at the following location to understand the reset process.
Page 31.
http://home.exetel.com.au/nds/NDSII/...%20Rev%201.pdf
cruce91
Sep 20, 2015 10:23 AM
intimidator
Sep 5, 2015 07:23 PM
maximusrising
Sep 2, 2015 09:55 AM
ef9
Aug 27, 2015 10:17 AM
