Ecu and ecm
Old Nov 5, 2014 | 05:54 PM
Sean O'Brien's Avatar
Ecu and ecm
My ecu/ecm is fried and i need to find a new ive searched lots of threads but still nothing the dealership quoted me $1400 to put a new one in screw that, i need some help any ideas?
Old Nov 5, 2014 | 07:11 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you can always send it to be fixed. There is a company in California that fixes ECU's. Don't remember the name but let me see if I can find anything for you.
http://circuitboardmedics.com/nissan-ecm-repairs/
Old Nov 5, 2014 | 07:12 PM
nestorlugo's Avatar
Start buy looking at the very bottom under the dashboard remove the cover on the passenger side unplug it remove the screws and take it out to inspect it.... burnt ecu/maxima.org
are you getting and codes?
Old Nov 5, 2014 | 07:20 PM
cdoublejj's Avatar
will have to buy used, you may also need a TCU and the key HAVE TO be reprogrammed the ECO no if and but, or any around it because it has an immobilizer.
screw the dealer. lock smiths have been known to reprogram key's chips or RFID.
EDIT: yeah you can get it repaired, http://www.ebay.com/itm/281014411783...%3AMEBIDX%3AIT
Old Nov 5, 2014 | 08:40 PM
Do you know where i can get a good rebuilt one both my vehicles are broken and im borrowing a car so i need it done asap
Old Nov 5, 2014 | 08:41 PM
Yes check engine light and a few others the nissan dealership told me ecu unit
Old Nov 5, 2014 | 08:51 PM
ateick's Avatar
Don't trust them. What are the codes? If you need one the wreckers is a good place to start.
Old Nov 5, 2014 | 08:54 PM
nestorlugo's Avatar
Should ask them for specific codes to be able to do a more thorough search.....or just buy a used one make sure it matches yours and have a locksmith reprogram it and be **** i mean done..if it is indeed your problem anyway...
Old Nov 6, 2014 | 01:27 PM
ManualMaxima's Avatar
5th Gen till she dies!
Originally Posted by Lontar1
you can always send it to be fixed. There is a company in California that fixes ECU's. Don't remember the name but let me see if I can find anything for you. http://circuitboardmedics.com/nissan-ecm-repairs/
I had a REALLY BAD personal experience with these guys, and WILL NOT RECOMMEND THEM IN ANY WAY!!!!!!!! Now that's just my opinion, and it was explained in a thread I made about my IACV/ECU experience. They are based in the Carolina's. Other shops may be fine to use with a recommendation...
Old Nov 6, 2014 | 06:53 PM
The_Fixer's Avatar
If you need a sta509 chip replaced in your ecu there is a guy on My5th gen FB group that does it but you need to k ow your codes first
Old Nov 6, 2014 | 07:19 PM
cdoublejj's Avatar
it's not always the STA509 chip. at least i'm not so sure it is always the case.
this guy, seems pretty decent seemed to pretty knowledgeable when i called.
Old Nov 6, 2014 | 07:41 PM
Originally Posted by cdoublejj
it's not always the STA509 chip. at least i'm not so sure it is always the case. this guy, seems pretty decent seemed to pretty knowledgeable when i called. http://www.ebay.com/itm/281014411783...%3AMEBIDX%3AIT
And how do find out it's the chip or not? Answer: pull the ECU as mentioned by other poster and take a good hard look. Or, call the shop that scanned your codes and ask them what codes they pulled; this should be included in your service records. Once you share what codes and such others can help you better. I think you'll find as myself and others have; ECU's get trashed by bad iacv's and motor mounts. Be prepared for this, and read up on the many threads on the subject on the boards (a wealth of knowledge is contained there). Good luck...
Old Nov 7, 2014 | 06:29 AM
cdoublejj's Avatar
been there did that. ECU was clean as whistle no burned marks, it was even stepping down the IAC on the Verus live scanner, turns out there an issue, it was still able to function, just not correctly. when i get my pay check i'll be updating my thread.
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
