5th gen audio
Old Nov 9, 2014 | 07:15 AM
jroc754's Avatar
5th gen audio
Im looking to pick up a dub din for my 02 SE and eventually add a 15'' sub. what kind of audio set ups u guys have and what do you suggest??
Old Nov 9, 2014 | 07:47 AM
tmab1234's Avatar
I got a pioneer avic which fit almost perfectly. I have a 99 infiniti I30 though but its a awesome deck. just doing the head unit has increased sound quality exponentialy.
Old Nov 9, 2014 | 08:09 AM
george__'s Avatar
Is it a BOSE system or not?
Old Nov 9, 2014 | 08:18 AM
1996blackmax's Avatar
Is your system completely stock right now?
Old Nov 9, 2014 | 06:29 PM
jroc754's Avatar
yea just the stock bose system right now
Old Nov 9, 2014 | 06:43 PM
jjubert's Avatar
I feel for you listening to that crappy stock bose system man...it was one of the first things that had to go when I scooped my max a couple of years ago. My setup now is a pioneer double din, and the sound quality of the stock speakers increased incredibly!
Old Nov 10, 2014 | 04:18 PM
Just wait till you replace those Bose speakers....it will sound even better.
Old Nov 10, 2014 | 04:42 PM
george__'s Avatar
money blown
Old Nov 10, 2014 | 05:17 PM
Blown...why?
Old Nov 10, 2014 | 06:21 PM
george__'s Avatar
Blown...why?
These cars are worth about $3500?
Audio system could run upwards of $600... That's 17.14% (~17%) of the value of the car.
Old Nov 10, 2014 | 06:27 PM
mrsandman's Avatar
I wouldn't say it's money blown at all...you need to replace the speakers and bypass the bose amp altogether for much better sound. the ohm rating for the bose speakers is set up for that bose receiver and if you do not change speakers and/or continue to use the bose amp/speakers with your new HU you will not get the full potential out of it and you will suffer from very low volume. I ended up re-wiring direct from my HU to my new speakers and the volume is much better.
Now here is the catch….wiring through your door jamb can be a PITA in the front especially, so I took a shortcut and intercepted the speaker wires coming out of the bose amp to the front doors and ran it that way. Put 6 1/2" Pioneers in the front door and decent sound. Too bad the rear on these cars only take 5 1/4 in the doors, so they don't do much by way of bass.
Old Nov 10, 2014 | 06:31 PM
So? Anything you put on/in your car can be viewed in the same way.
By the way....system could run lower as well.
Old Nov 10, 2014 | 06:32 PM
george__'s Avatar
Yup very true.
https://www.youtube.com/watch?v=SQTcRxPsoMo
Old Nov 10, 2014 | 06:44 PM
5.5SE6MT's Avatar
Blown...why?
Awwww. I guess word hasn't gotten around, you're supposed to ignore that wingnut .. george__.
His creepy *** feeds off your responses -_-
Old Nov 10, 2014 | 09:01 PM
I've actually seen his post before....
Creepy is right
Old Nov 13, 2014 | 01:16 PM
Cotozic's Avatar
I have replaced all my speakers, got a head unit, 2 amps, and 2 12" subs.
Honestly, I only recently replaced my tweeters with a component set from Infiniti, as I had started my upgrades by simply changing my door speakers and installing subs, but didn't consider how amazing aftermarket tweeters would sound compared to the stock. It takes time and money, but replacing any of the speakers in general is a real upgrade when paired with an aftermarket head unit. Subs will do the trick to start with, but amped door speakers and tweeters were the next level for me, as they helped level with the power of the subs. All of it comes together wonderfully.
So yeah, really anything is an upgrade from stock.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
