Tokico illumina Adjustment Indicator missing
Old Nov 15, 2014 | 05:42 PM
I30T 2000's Avatar
Here is a question for those knowledgeable about the Tokico Illumina adjustable rear shocks.
The new Tokico Illumina rear shocks I put on my 2000 Infiniti I30t did not come with the red inidicator for adjustment setting. I called the new Tokico distributor, they said to they didn't have them, but to "call back in a month to see if we have anything new to say."
I could get the setting I want without the indicators, if I could figure out where the "5" setting is on the dial.
My Question: The adjustor is inside the top of the strut shaft, and has five positions. The strut shaft has a flattened spot on one side, and a flattened spot on the other side. The flattened area on one side is much more flattened than the other. The "5" on the missing indicator lines up with one of these two flat sides. ON WHICH SIDE does the 5 line up? If I know that, I can choose the correct setting.
Thank you! (And poop to the new Tokico distributor for not being any help.)
Old Nov 28, 2014 | 09:39 PM
Mattx's Avatar
Yes the flat spot on the adjuster is where the number five should be. Make sure you only turn them clockwise.
Old Nov 30, 2014 | 08:25 AM
CMax03's Avatar
I have same rears and fronts Illuminas I just removed, I can check and verify that I do have them!
Old Nov 30, 2014 | 08:30 PM
CMax03's Avatar
I have the fronts and rears indicators....
Old Nov 30, 2014 | 09:12 PM
Mattx's Avatar
When I got mine the fronts were chipped off do you think I could have your old fronts only??
Old Dec 1, 2014 | 09:38 AM
CMax03's Avatar
Sure how much $100?
Old Dec 1, 2014 | 09:39 AM
CMax03's Avatar
You need the inner adjuster or the outer indicator?
Old Dec 1, 2014 | 02:30 PM
Mattx's Avatar
I just need the part that has the numbers on it.
Old Dec 1, 2014 | 02:56 PM
CMax03's Avatar
How much do you think it's worth including shipping thru USPS...
Old Dec 1, 2014 | 07:27 PM
Mattx's Avatar
In the grand scheme of life it's worth shipping to me. I look at it as a good karma thing for you. I did buy that resonator from you if that helps.
Old Dec 2, 2014 | 05:53 AM
CMax03's Avatar
In life there's nothing free...pick a price...$10, $20, $30, etc, this items are priceless....Since there's now way of ordering them...
Old Dec 2, 2014 | 07:50 AM
Mattx's Avatar
You can throw them away then. I don't need them they would just be nice to have and since you were going to throw yours away i figured I'd ask.
Old Dec 2, 2014 | 09:48 AM
CMax03's Avatar
Nope wasn't throwing them away....I saved them cause people somehow lose or damage their own... I'd figure they would be worth $10-$20....
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
leatherneck
Sep 30, 2015 09:16 PM
