Seat heater pad replacement
Winter sucks, especially when you have a broken seat heater. I notice that they have some kind of universal seat heater kit on Amazon or so. Can they replace original heater pad inside our driver's seat?
Anyone did this before? need some advice. thanks.
You sure its not the switch?
In that case you are right the switch is fine. Where you are losing continuity is in the heating element of the seat. Check the wiring in the seat you may find a break that you can fix. Probably easier than installing entirely new elements.
Otherwise consider a heating element from a seat at the junk yard. I think they are removable. Get the passenger side it would have less wear than the drivers side.
The universal elements usually require that you use their control switches so easier to go with OEM replacement if you can find one.
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
