2002 GLE 4-Speed Automatic problems
Old Nov 20, 2014 | 12:40 AM
robosaki's Avatar
Hello,
I have a 2002 GLE 4 speed automatic, and I've started to experience strange shifting problems in the past weeks and months. The Engine itself is in very good condition to the best of my knowledge, with Oil changes & new K&N Filter every 4-5k miles.
When I shift from N to D, the shifter does not land directly on D. It instead lands somewhere in between 3 & D. However, when I push the shifter into 3 position, and then back to the right on D, it slides completely into D groove. This was not an issue until recently.
I'm confused about this, it seems like it may be a precursor to something breaking down in the transmission assembly or the shift cable going out.
Thought I'd also share some extra information regarding this vehicle:
The transmission has been hard shifting for a while now (months), especially when cold... much less when warmed up. The engine seems to jump/move under the hood quite a bit when I switch from Neutral to Reverse...
The engine has 145,000 miles on it. I've changed the transmission oil and filter about 10-15k miles ago. At the time I was experiencing hard shifts as well, the old fluid was in good condition and there was barely any dirty residue. (I thought the old filter was clogging up).
I don't know if this is normal, but whenever I accelerate and let go of the accelerator I always feel a little gap, or delay disconnects or something. This is especially noticeable at lower speed and traffic, it almost feels like a lag effect... and it happens all the time!
When entering highway and flooring the engine on high RPM, and I believe switching from 3rd gear into 4th... I've recently started to hear strange sounds... different than before. It happens right on the gear change, like the transmission is sucking in something. (If you close your mouth and try to suck in air through the mouth)
Its hard to explain but the closest sound I could come across that resembles my symptom is this.
https://www.youtube.com/watch?v=S3LhQaQcLeE 0:10 ( @10 seconds in the video)
Finally, could this be something serious that I should immediately take to the Dealer or mechanic?
I've asked my mechanic a few months back about hard shifting, and he suggested those transmission additives from Auto Zone since the car already has some years on it. He mentioned that the rubber rings & seals may be going out, so those additives may help make things better. I did not follow his suggestions, after doing some research I concluded that those cheap transmission additives might do more harm than good to my transmission.
Another idea I've been thinking about is buying a 2002 Maxima Automatic Transmission Rebuild Kit, and having a professional Transmission mechanic rebuild it for me... because it sure sounds like the transmission is slowly going out.
I plan to use this car for as long as possible, I believe this car can make 200k miles easily when maintained correctly.
My apologies for the long write-up, I wanted to include all the problems I've been experiencing with my 2002 Maxima GLE Transmission, in the hopes that maybe someone here could share some productive thoughts or solutions.
Thank you for your time!
Mar 12, 2020 12:06 AM
QueensMAX
Sep 15, 2015 04:14 AM
Colossus
Sep 9, 2015 05:46 AM
GregL65
Sep 7, 2015 10:33 PM
Justin Kroll
Sep 2, 2015 11:06 AM
