Correct 5th Gen AC Bypass Belt
Old Nov 20, 2014 | 11:22 AM
eclivic's Avatar
2000 Maxima 3.0
I have searched for two days looking for the correct belt to bypass my A/C Pulley..
Two choices
1. 3706K Belt will work but it only has about 1/4 inch before the belt "Might" rub.
Can be purchased at local part stores.
Length: 37"
# of Ribs: 6
Features:
• Mainly used for automobile serpentine drives. Also known as K or PK Micro Rib Poly Belt
• Reduced vibrations, shock absorber, low stretch and an excellent behavior under heavy load.
• Extremely flexible, capable to work on small pulley diameters.
• Oil and heat resistant.
Replaces:
• Dayco - 5060370
• Gates - K060370
• Goodyear - 4060370
• Metric Belt Code - 6PK0937
• Metric Belt Code - 6PK0938
• Metric Belt Code - 6PK0939
• Metric Belt Code - 6PK0940
• Metric Belt Code - 6PK0941
• Napa - 25060370
2. 365k6 Should work a lot better and give more space between the belt touching.
Will most likely need to be ordered online. http://www.vbelts4less.com/ or someplace else.
Length: 36.5"
# of Ribs: 6
Features:
Replaces:
• Dayco - 5060365
• Gates - K060365
• Goodyear - 4060365
• Metric Belt Code - 6PK0925
• Metric Belt Code - 6PK0926
• Metric Belt Code - 6PK0927
• Metric Belt Code - 6PK0928
• Metric Belt Code - 6PK0929
I did install choice 1 and it works perfect but I will be ordering the second choice.
Old Nov 20, 2014 | 03:13 PM
DennisMik's Avatar
To bypass the ac, you need a belt that is 920 mm or 36 inches. That would be metric code 6PK0920.
There have been a bunch of posts in the past about this, so I'm surprised that you weren't able to find this. Others have said they used a 37" belt, so you are probably OK with that.
Old Nov 20, 2014 | 05:36 PM
cdoublejj's Avatar
well it doesn't help the forum upgrade broke all the URL links to other posts in all the older posts as well as the FAQs and stickies.
Old Nov 20, 2014 | 07:30 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you need this one...
DAYCO 5060370, 6PK940. I just did it to my car and I had issues with the 36", the 37" fits perfectly.
Old Nov 21, 2014 | 08:57 AM
Y2kMaxima's Avatar
I forgot the part number but I did use the 37" 6 rib as well and worked completely fine. Just sucked Cus I had no ac.. Lol
Old Nov 21, 2014 | 04:28 PM
Lontar1's Avatar
I wont need the AC for now.. it is 29 degrees out there. The car is going to my son in a few months and he is in Florida.... LMAO... he is screwed...
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
markevans999
Oct 25, 2015 08:27 AM
Lowered_a33
Sep 1, 2015 07:49 PM
