Having Trouble taking Rear Lens off...
I was trying to install my rear clear markerHey and I was wondering if any of you have experienced a hard time taking off the rear red lens on the 2k2.. I tried following the instructions on it but it would not come off. and on top of it I CHIPPED My PAINT!!!!!! I want to cry.. GRRRR.. .. any tips for me?? before I have a heart attack of my car being chipped ? PLEASE help thanks ..
Re: Having Trouble taking Rear Lens off...
also use a rag under your screwdriver to protect the paint
I had the same problem with mine. Sometimes it is easier to try it from the other end. You would think it is easier to go for the end with the spring end but it wasn't the case for me on the rear markers.
Hope this helps.
Jeff
Hope this helps.
Jeff
Try going from the end that doesn't have the spring clip on it (I think it is towards the front of the car). Using a small flat blade screw driver slowly ease it in behind the marker. At this point I was able to pull the lense out with my fingers. The further you can get the screw driver behind the lense without chipping the paint the easier it will be to remove.
Jeff
Jeff
Huttig2009
09-25-2015 03:31 PM
laparka66
08-06-2015 09:36 AM
