2k2 HIDS on 2k Max
Old Jan 23, 2002 | 09:37 PM
kpark's Avatar
2k2 HIDS on 2k Max
I wired a pair of 2k2 HIDs on my 2000 Maxima using instructions I found here. I noticed that when they are on and I'm signalling that they flicker when my turning signal turns to the off position after completing my turn. Anyone else experiencing this problem?
Old Jan 24, 2002 | 04:54 AM
UMD_MaxSE's Avatar
Got Bent?
no such problem here... are you sure all the grounds are straight?
Old Jan 24, 2002 | 07:54 AM
BigDogJonx's Avatar
Um yeah, I think you wired the Xenons ground wire to the ground wire of maybe the turnsignals. The Xenons ground wire should be straight grounded to the Body.
Check my writeup if you think you messed up. Go to my Homepage.
Dixit
Old Jan 24, 2002 | 08:54 AM
Newman's Avatar
[ladies man]Um yeah, I think you wired the Xenons ground wire to the ground wire of maybe the turnsignals. [/ladies man] ??
Old Jan 24, 2002 | 10:37 AM
BigDogJonx's Avatar
What you implying? Cause I aint follow you.
Dixit
Old Jan 24, 2002 | 11:12 AM
Newman's Avatar
Dixit
nothing really. just the way you said "Um, yeah..." reminded me of the ladies man. no big deal.
Old Jan 24, 2002 | 11:57 AM
kpark's Avatar
Dixit
The HIDs are grounded directly to the body. Any other ideas?
Old Jan 24, 2002 | 12:09 PM
BigDogJonx's Avatar
Go over my wiring setup on my homepage, and tell me what you have done differently.
All I can think of is that the turnsignal wire somewhere along the lines must be shorting out with the 12V for the Xenons,
Also do this so I can rule this out, turn on the highbeams and do the turnsignal, does the highbeams also do it? This only needs to be done if you followed my wiring diagram, if you got the 12V for the Highbeams from the battery, then this step does not need to be performed.
Explain it in detail for me.
Dixit
Old Jan 24, 2002 | 12:43 PM
DSLKnight's Avatar
Do you get the HIDS kit from a Nissan dealer or is there some other place where you can get them?
Old Jan 24, 2002 | 01:25 PM
TimW's Avatar
The silent but deadly Moderator
your ground points
are they free of paint? metal to metal? I used the factory points on each side, conveniently close to the lights.
Old Jan 24, 2002 | 01:29 PM
BigDogJonx's Avatar
Re: your ground points
Yeap that is what i used too.
Dixit
Old Jan 24, 2002 | 01:45 PM
kpark's Avatar
No. Where did you find factory points? I couldn't find anything to ground them too. I ended up screwing them in near the top front lip of the hood. Any other place that looked ideal wouldn't unscrew.
Old Jan 24, 2002 | 05:44 PM
BigDogJonx's Avatar
Re: Re: your ground points
If you look right behind the headlight assembly, there is a screw on the passenger side holding like almost 5-7 ground wires already, the other drivers side has the same deal also.
Dixit
Old Jan 24, 2002 | 07:01 PM
radpp16's Avatar
Re: 2k2 HIDS on 2k Max
yeah Dixit's writeup is great... helped me entirely
ROger
Old Jan 24, 2002 | 07:26 PM
myktek's Avatar
hehee, i used BigDogJonx writeup. . .thanks again for all the help to all the ppl. . .hehehe. . .3 months and going. . .no probs yet....
Old Jan 26, 2002 | 01:12 AM
BigDogJonx's Avatar
Who's this BigDogJonx guy you people seem to talk about?
Hahhhhaaaaaaaaaaaaa
Dixit
Old Jan 26, 2002 | 10:18 PM
theMax's Avatar
did you do the side marker rewire? Maybe that is messing it up?
Old Jan 26, 2002 | 10:53 PM
BigDogJonx's Avatar
I have the side marker wire (both front and rears) and that was BEFORE I even changed over to the 2K2 HIDs and I had no problems.
Dixit
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
