p0134
Old Dec 31, 2014 | 07:10 AM
bennuss's Avatar
p0134
Just started getting this no activity on the bank 1 s1 o2. I changed this one about 6 minths ago used a denso. I ran my car while monitoring thw sensor and it has periods that it gives no reading at all. Usually a bad o2 gives a reading out of range. The connection looks good .
I also got a p0140 with same no activity on b1 s2 . That one I cleared and hasnt come back.
Anything else I should look at? Maybe further up the wiring harness?
Old Dec 31, 2014 | 08:34 AM
george__'s Avatar
Wouldn't be surprised if the part died... These cars so picky with parts
The P0134 code means you need to change out that front oxygen sensor ASAP since it actually has a useful job, dealing with A/F ratio. Don't fix it and you'll probably have poor gas mileage, lack of performance and more . P0140 is rear which isn't as important, just checks to see if precats are working.
Old Dec 31, 2014 | 09:15 AM
bennuss's Avatar
I realize its important but no activity instead of out of range values is unusual. They usually dont die like that unless they get banged and crack.
my precats I am sure are gone but they are way to rusty to even attempt to remove them and gut.
Old Dec 31, 2014 | 09:33 AM
george__'s Avatar
Old Dec 31, 2014 | 09:36 AM
bennuss's Avatar
Mine is intermittent n since it happens for a moment with no response from thr o2 at all not just values out of sync. Then it goes back to working correctly with the values exactly where they should be.
Old Dec 31, 2014 | 09:42 AM
george__'s Avatar
change it
if it comes back check other components?
Old Dec 31, 2014 | 01:28 PM
ac max 92's Avatar
Sounds like a broken wire somewhere in the harness.
Old Dec 31, 2014 | 01:39 PM
bennuss's Avatar
how would i find it . the harness runs under the upper radiator support and is all interconnected.
Old Jan 1, 2015 | 05:08 PM
bennuss's Avatar
I am getting a p0140. Does anyone know where the wires converge. It would be a good place to start
billm
Apr 20, 2014 10:10 AM
Tee00Max
Dec 2, 2010 04:14 PM
t65k3
Mar 13, 2010 06:21 PM
mendezrj03max
Dec 31, 2009 04:28 PM
enik23
Sep 14, 2008 07:33 PM
