MAX ATF for 02 Maxima?
Old Dec 31, 2014 | 08:38 PM
Alexyan's Avatar
Royal Purple MAX ATF for 02 Maxima?
Hi guys. There is this weird sound coming from the front of my car for about a year now and no one could figure out why. Until recently someone says the noise could be from the transmission. So I am thinking of changing from my current Dextron III fluid to MAX ATF (fully synthetic) might help?
Weird Sound: https://www.youtube.com/watch?v=qIthuxp4AGU
MAX ATF® – SYNTHETIC AUTOMATIC TRANSMISSION FLUID:
http://www.royalpurpleconsumer.com/p...mission-fluid/
Any input would be appreciated
Old Dec 31, 2014 | 08:57 PM
ac max 92's Avatar
The video seems to pause and stop around 11 seconds so can't make anything out. Is the noise happening going straight or when turning? Have you checked the fluid levels and checked the power steering? Amsoil multi vehicle ATF is a good synthetic too.
Old Dec 31, 2014 | 09:32 PM
Donkeypunch's Avatar
I hear just road noise.
Old Dec 31, 2014 | 09:33 PM
Alexyan's Avatar
It's very loud at 0:04
Old Dec 31, 2014 | 09:35 PM
Alexyan's Avatar
It happens both straight and turning(but it comes and go), yeah I'm gonna check them tmr
Old Dec 31, 2014 | 11:03 PM
Cotozic's Avatar
Notice anything unusual about the car changing gears? Any slipping?
Old Jan 1, 2015 | 05:32 AM
george__'s Avatar
You 100% sure the transmission is okay and fluid is filled up?
Sounds like something's scrapping?
Old Jan 1, 2015 | 01:46 PM
Alexyan's Avatar
I just checked it today at Vaughan mills while the engine is hot, it looks like it's overfill. I don't know if the reading is accurate though 'cause the parking lot is not really that flat.
Btw, would it leak if I change the fluid to fully synthetic, since the tranny is old?
Old Jan 1, 2015 | 01:54 PM
george__'s Avatar
And car drives fine?
Old Jan 1, 2015 | 02:08 PM
Alexyan's Avatar
Yeah, very normal except for that abnormal sound 😒
Old Jan 3, 2015 | 09:18 AM
Chris Gregg's Avatar
Get Off My Lawn
So no vibrations?
Sounds to me it is a vibration rattle. It's only a guess, but I'd inspect your exhaust system for droop due to bad isolators - so it could be moving and/or rattling. Sounded more substantial than a heat shield, but I'd check those too.
I'd also check for a bad idler pulley or accessory pulley. I've heard some loose idler pulley's sound like that. They are tight against the belt, but the bolt holding it and the bearing in place is loose causing it to rattle from time to time.
Old Jan 3, 2015 | 04:16 PM
Alexyan's Avatar
Originally Posted by Chris Gregg
So no vibrations?
It sounds like a vibration to me too but I don't "physically" feel it though
I'm gonna check the other parts too. Thanks
Old Jan 3, 2015 | 04:31 PM
george__'s Avatar
Did your car ever have its axles changed?
Aftermarket axles usually are missing a vibration dampener
Old Jan 3, 2015 | 04:34 PM
Alexyan's Avatar
Tbh I don't know. I bought it used -.-
Old Jan 3, 2015 | 04:45 PM
george__'s Avatar
Suspension?
Old Jan 3, 2015 | 07:17 PM
Alexyan's Avatar
Suspension?
Besides the four struts are a bit worn out, the rest are fine lol
dank4us
34
Jun 10, 2024 03:45 AM
CRizz
41
Jun 7, 2021 05:42 AM
Supragte
Aug 12, 2015 10:00 PM
jholley
Aug 11, 2015 09:38 AM
dauntlessmax
Aug 5, 2015 10:29 AM
