Negative Terminal Starts to Spark please help
I just finished installing my starter. Before I did anything I removed the negative battery terminal. Once I was finished with the job, I tried putting the negative terminal back in and it starts sparking right when it touches the battery. The sparking is continuous if I leave it on the battery and there's nothing else I can do but leave it off. Can someone please help me or give me some sort of feedback on how I can go about this? please please please
Some small sparking is normal when reconnecting it back. If it continues afterwards you most likely have bad contact on the post- clean it and the wire terminal with sand paper, put it back and tighten the nut. If the sparking is excessive (with smoke, heat, etc) you might have a short somewhere and you better fix that first but I doubt it's your case.
Don't keep it there or you'll kill your battery and do what the other poster ^^^ suggested, seems you pinched power wire while replacing starter. By 'killing' I really mean it, not just draining- batteries don't tolerate shorts very well.
Thanks. I was kinda scared cause I thought my maxima was gonna blow up lol. What do you guys mean by the power wire?
Most definitely could be this. A loose connection or a short could definitely cause problems. I had a loose grounding wire on one of my amps and that caused sparks to fly like crazy.
The negative wire should go to the engine already cause i haven't messed with that. I think my problem is the positive cable. I'm going to re check that today when I get home
The lamp will limit the current passing through it to the level it is rated for saving your battery and providing indicator if the problem still exists. Normal leak current of the car is in mA range and it is way not enough to lit up the lamp of that wattage.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
