RockAuto Lower Control Arm for $53???
Old Jan 6, 2015 | 12:53 PM
matts95max's Avatar
Why is this part so cheap? Its double at Autozone and almost triple at Courtesyparts.com. The salvage yard wants $50 for a used one! Anyone have insight on this?
Thanks,
Matt
Old Jan 6, 2015 | 02:52 PM
nestorlugo's Avatar
Thanks,
Matt
None wrong with it...go for it cuz
1.AutoZone (made in china mark up)
2.Oem (98% of the time outrageous doh)
3.slap them
Even better if you refurbished yours ,buy the moog balljoint,and es bushings, quite a bit of work but will be solid.
Old Jan 6, 2015 | 02:58 PM
NmexMAX's Avatar
dot dot dot ...
Don't they have different grades/tiers/etc, like Raybestos, etc?
Old Jan 6, 2015 | 03:00 PM
CMax03's Avatar
For the 5th Gen there's two MOOG LCA's!!!! The best one is their Problem Solver Line! the economical LCA lacks a greaseable Lower balljoint (a sealed balljoint), the Problem Solve Line come with a greaseable lower balljoint that includes a grease zerk!!!! The 4th Gen Moog LCA is only available thru MOOG as the econo line! but you can go with Raybestos Professional Line which is good also!!!!Rockauto for the win!
Old Jan 6, 2015 | 04:15 PM
matts95max's Avatar
I didnt notice, but yes they do have different tiers. I went ahead and bought the Beck/Arnley LCA before reading this.
I cant refurbish mine because its bent. Destroyed.
Thanks for the info! I might see if they can cancel my order and Ill order the MOOG one.
Old Jan 6, 2015 | 04:40 PM
nestorlugo's Avatar
Maybe if it hasn't shipped i don't see why not....
Yea i had a feeling yours was damaged since you only asked for one,but in any case the used one for $50 is too much , if you could have got a used one for the low es bushings and moog balljoints is the way of the yoda. may the force guide you buddy
Old Jan 7, 2015 | 04:30 AM
rbaksi's Avatar
I bought both of mine new from eBay a couple years ago for about $60 shipped each. They have held up well without issue.
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Bonka
Sep 14, 2015 11:18 PM
