whats normal compression on a vq35? buying a used engine
Old Jan 7, 2015 | 10:55 PM
carsnwomen91's Avatar
i was browsing car-part and i believe i found a contender for a swap. the notes in the listing read as follows
2003 maxima OIL 74-20,50@2000,COMP 200-220 77k miles/124k km for $1000CAD + taxes
-i called and found out a few things but i forgot what the 'oil 74-20' meant... something to do with oil pressure cold idle vs hot (i'll call back and check).
-50@2000 means 50psi oil pressure at 2000rpm
-and 200-220 compression reading (dry)
i was really happy to see such a high compression reading over the others, is this normal? i figured high compression reading = good ring seal = no to very little oil burning
so what do you guys think of those numbers, this a good buy? whats the stock healthy compression reading?
Old Jan 8, 2015 | 07:00 AM
NmexMAX's Avatar
dot dot dot ...
IIRC somewhere in the 185 PSI range.
FSM now ...
Originally Posted by 2003 FSM EM-88
Unit: kPa (kg/cm2, psi)/300 rpm
Compression pressure
Standard 1,275 (13.0, 185)
Minimum 981 (10.0, 142)
Differential limit between cylinders 98 (1.0, 14)
Old Jan 8, 2015 | 10:39 AM
q.man06's Avatar
Compression speaks nothing in regards to oil consumption. You have oil control rings, and compression rings.
Get one from a newer altima or maxima (08+) and be done. Zero oil consumption since I swapped the HR version in.
Old Jan 8, 2015 | 11:45 AM
NmexMAX's Avatar
dot dot dot ...
True, CR could still be on par and it could still drink oil and produce power, i.e. have gooda good CR.
But I'd rather go with an 09 Maxima engine vs an 08.
Old Jan 11, 2015 | 08:43 AM
faaaack i forgot about that lol! well i don't know if the guy swapping my engine can do that much newer of a swap, its not drop in though but omg i would love little to no oil consumption
whats the differences after 06? i now the 04-06 have external egr, different KS sensor plug/harness and injector clips iirc. its ok coming from a cvt car?
09 is way too much work for this guy i saw the 5.7 gen
Old Jan 11, 2015 | 08:59 AM
george__'s Avatar
Isn't the issue with the pistons?
For $1000 you could buy a entire gen 5.5 car......... Part it out and sell, if you plan to rebuild a motor
Old Jan 11, 2015 | 09:28 AM
i read your 08 altima motor swap thread and thats too involved for what kind of resources i have. i mean my car is going into a garage and my buddy can do a thing here or there but it has to be mostly a direct swap cause i need to get it running A1 asap and be out of the garage.
as i was reading your thread on page 3 supra11 tried to jack your thread with 07 maxima motor swap lol thats what i want to do since SurraTT mentioned right after that, that only a few components need a swap, is this true?
Originally Posted by SurraTT
if its a 08 maxima vq its no issue. swap upper oil pans from old motor maybe fuel rail, knock sensor done.
if its a 08 altima vq then its a whole different issue. as this thread is for 08 altima vq.
can someone point me to more info on swapping 07-08 maxima vq35 into 5.5 gen?
Old Jan 11, 2015 | 09:30 AM
motor rebuild is about $5k a used 6.5 gen engine and swap is a little less than half of that
Old Jan 11, 2015 | 09:51 AM
george__'s Avatar
A 2007-2008 Nissan Maxima is a gen 6 maxima. It's easy swap without too many complications
https://maxima.org/forums/5th-genera...o-5-5-gen.html
https://maxima.org/forums/5th-genera...me-engine.html
Old Jan 11, 2015 | 10:53 AM
ok i've read the first thread lots of good info to swapping an 04-06 engine.
what i've learned is:
-swap the fuel rail for same connectors
-swap the IM because 02-03 has no egr (if the 02-03 egr is internal wouldn't a newer engine essentially delete it?? i don't get this)
-swap the knock sensor to 02-03 and re-use 02-03 harness
-swap the CPS when going from auto to manual (how do you know where to mount it on the manual??)
-swap upper oil pan to manual when using auto engine
thats for 04-06 but i'd really like an 07-08 max vq35de. oil consumption is still reported by some (not as bad) but i'd like to avoid it as much as possible if i can with a newer vq with as little work as possible.
is there more to swap on 07-08? did they have a plastic intake manifold? cvt to manual swap differences? i need to know as much definitive info as i can, i can't be figuring stuff out on the fly because i'm not doing a swap and i need to tell my friend all the info necessary to not take up the hoist for more than i plan.
04-06 is 6g 07-08 is 6.5g just like 00-01 is 5g and 02-03 is 5.5. its the same car but refreshed, hence the .5g
Old Jan 14, 2015 | 08:25 AM
ok so i did a little more research in choosing an 07-08... thanks again to aackshun's guide i found these bolt right up with the same changes you'd do to an auto 04-06 minus that these ones don't have egr in the intake manifold AND its plastic like the 00vi
gonna look for some 07-08's!
Old Apr 13, 2015 | 03:10 AM
heavychevy's Avatar
Workin on a 2007 the upper intake is aluminum exactly like a 2002-2006.everyone says it's plastic am I missing something here?
Old Apr 13, 2015 | 08:51 AM
No the guide has some wrongs... But 07-08 is even more bolt on than 04-06. The cps is in the same place and the oil pans remain the same, so just jus the knock sensor and injector clips are different and maybe a 1-2 other clips but easy. You may still have to replace the timing chain tensioners before you drop it in, those years still had some issues.
Old Apr 13, 2015 | 01:05 PM
heavychevy's Avatar
Got the motor pulled today finally. 8 was just going to ask if they still had timing chain tension issues
Old Apr 13, 2015 | 04:16 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Exactly why 6th gen motors aren't worth it. By the time you replace that crap (pain in the ***), you might as well just use a 7th gen engine or the 07+ altima/09+ quest, etc.
It's much easier to solder some wires and cut a little aluminum off than disassembling the entire timing system.
MAXSE5SPD
Sep 17, 2022 04:00 AM
iflexsteel
Sep 2, 2015 08:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
