Radiator support part??
Hey guys, few quick questions, i've also attached pictures for references. also, keep in mind the cross member has been detached from the radiator for some time now. lets assume 1 year due to the progress of the rust.
1) From the pictures shown of the engine mounts, cross member and radiator support.....will replacing the radiator support fix this issue?
2) Do I need to change all four engine mounts since the two with all the weight on them are probably ready to go soon?
3) also, the most important question is. if i change the radiator support with the replacement that's shown in the last picture below. will this solve everything or is there anymore parts or anything else I'm not aware of?
4) Are there any other easier or less expensive way to permanently fix this.?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I had the same issue with mine. What we did was just cut out all the rust and renforced it with new metal. Way stronger than factory i would say. And undercoated the inside which will hopefully preventing it from rust again. Also after this my motor mounts are still fine. Last thing is a factory peice is the way to go if your changing it completly ive heard that the aftermarkets are too weak and rust way to quick!
Good luck!
Good luck!
MR2 T'd
07-09-2021 05:06 AM
pktaske
05-06-2016 07:49 AM
