5th gen engine probs
Old Jan 10, 2015 | 03:47 AM
Blake2000's Avatar
I want to know if anyone has had problems with their oil pressure sending unit is that a common problem with 5th gen?? Also, has anyone had to replace their wheel axel boot? Im looking to get it replaced soon i want to eventually put lowering springs on. THANKS
Old Jan 10, 2015 | 05:20 AM
george__'s Avatar
Unless you are dropping real low you shouldn't have to replace the axle boots (CV boots).
Old Jan 10, 2015 | 06:24 AM
D.Stillwell's Avatar
I don't think oil pressure sending unit is a very common problem, but I've seen some people have problems with it. Usually it's the seal that starts leaking on higher mileage cars, not the unit itself that's bad.
I had to replace my axles, and that was before I did my suspension. Meaning my boots were shot on stock suspension and only after 90k miles. That said, just don't go too low (less than 2" drop) if you don't want more axle problems in future.
Old Jan 10, 2015 | 12:21 PM
Blake2000's Avatar
Thanks D.Stillwell and george__
Old Jan 10, 2015 | 01:59 PM
george__'s Avatar
If you do replace the actual axle, you need to get axles with VIBRATION DAMPENERS.
Old Jan 11, 2015 | 01:48 AM
Aftermarket axles pretty much dont have that rubber damper but its really not an issue, so long as the axle itself is quality. Millions of used cars on the roads without those dampers.
My axles are new and no issues, there was no vibration dampener.
Old Jan 11, 2015 | 06:37 AM
george__'s Avatar
Maybe it has to do with your mount setup
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
