Rear struts
Old Jan 10, 2015 | 11:54 PM
egali045's Avatar
Rear struts
Is there any other way to remove the top nut that's hard to get?
Old Jan 11, 2015 | 01:18 AM
Fakie J Farkerton's Avatar
Remove the strut, use spring compressors<~correctly, and then zip off the center nut with an impact gun.
Old Jan 11, 2015 | 06:30 AM
george__'s Avatar
+1. Impact gun is the bomb.
Here are some pictures
Old Jan 11, 2015 | 11:21 AM
egali045's Avatar
Hey guys sorry for the misunderstanding I'm trying to uninstall it from the car. I'm not trying to remove the coil spring. Just the 2 nuts attached to the car
Old Jan 11, 2015 | 11:23 AM
egali045's Avatar
It's very hard to get to one of the nuts in a very tight spot.
Old Jan 11, 2015 | 11:24 AM
george__'s Avatar
http://www.shiftice.com/strut_install.html
try using a super long extension and going in from the top instead of trying to fit a wrench inside that tiny area...
For that nut closet to the car try going in from the rear seat instead of getting into the trunk
Old Jan 11, 2015 | 01:04 PM
I unbolt mine when sitting in the backseat as well. Good suggestion.
Old Jan 11, 2015 | 01:52 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You have to take off the brace blocking it by removing all the bolts from behind the rear seats.
Just do it. There's no point fighting it and rounding it off. It's much easier and faster to just disassemble the whole thing.
Old Jan 11, 2015 | 02:07 PM
nestorlugo's Avatar
That's exactly what i did when i overhauled the suspension, it's a shiet load of bolts just to get to the far back one
Old Jan 11, 2015 | 09:16 PM
egali045's Avatar
Is it the one with like 4 gold bolts on each side?
Old Jan 11, 2015 | 09:17 PM
egali045's Avatar
Also i installed the front ones and for some reason i hear a knock in one of them. Any clue. It's every certain bump
Old Jan 13, 2015 | 06:38 AM
djfrestyl's Avatar
Suspension Yoda
You DO NOT have to remove the entire black brace (huge waste of time). You need an extension on your socket wrench. You don't even need a U-joint. It can be done from the trunk.
Old Jan 14, 2015 | 05:04 AM
CMax03's Avatar
A 6" extension and 3/8" ratchet gets it done all the time without removing the brace!
Old Jan 14, 2015 | 05:06 AM
djfrestyl's Avatar
Suspension Yoda
QFT. So easy.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
ef9
Sep 5, 2015 11:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
