rough idle, bucks at low RPM when cold
Old Jan 11, 2015 | 03:43 AM
allthumbs's Avatar
I have a 2000 SE 5sp with 191K miles. Idle is ok at first, then becomes rough after a couple of minutes, almost to point of stall.
When engine is cold, especially when outside temp is in 30F or less, the car bucks severely under light load.
Apart from that, it run fine, gives same gas milage as when it was new.
I ran a few cans of sea form through it and that helped, but cannot get it back to normal. IACV? Fuel filter? ECU? Which is most likely, I can start there.
Old Jan 11, 2015 | 02:27 PM
nestorlugo's Avatar
Remove the ecu and check for the sta chip if is burned post pics the fixer might be able to help...
I think the cold weather is making all these issues appear ....wuz up with all these p0505 threads lately??? Everyone's ecm didn't burn in the same week
Even my car threw the code along with the p0420 after the engine bay cleanse a few days ago
Old Jan 11, 2015 | 09:04 PM
maxiiiboy's Avatar
To resolve your problem, try to answer the following questions:
  • Is the CEL On/Off?
  • When you check with ODBC reader, are there any codes?
  • Any "incomplete" monitors?
  • Does the car stall because of too much fuel, or because it does not have enough fuel? Do you smell gas when the idle becomes rough?
  • What is the condition of your spark plugs?
Old Jan 11, 2015 | 10:18 PM
iShiraz's Avatar
I have a 2000 SE 5sp with 191K miles. Idle is ok at first, then becomes rough after a couple of minutes, almost to point of stall. When engine is cold, especially when outside temp is in 30F or less, the car bucks severely under light load. Apart from that, it run fine, gives same gas milage as when it was new. I ran a few cans of sea form through it and that helped, but cannot get it back to normal. IACV? Fuel filter? ECU? Which is most likely, I can start there.
You most likely have the same thing as me. I have the P0505 code. Check if your ECU is fried first. If not you can just Replace your Throttle position sensor and IACV. If it is frie, ur gonna have to replace it and get it re programmed and then replace the TPS and IACV. That's what I'm doing.
Old Jan 12, 2015 | 03:40 AM
Max_5gen's Avatar
Any error codes? How did the problem start? Have you checked for intake vacuum leaks provided you don't have any error codes?
Old Jan 13, 2015 | 03:44 AM
allthumbs's Avatar
Reply rough idle questions
No codes thrown. No gas smells. Started at about 180K miles. Ran some Sea Foam thru system and that helped quite a bit, but cannot seem to get it to normal. Is it possible to have OBD info that does not show as a code display?
Old Jan 13, 2015 | 09:34 AM
Child_uv_KoRn's Avatar
Bad *** Newb
As I always say, (whether right or wrong) sounds like maf lol
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 10, 2015 09:35 PM
slowlifer
Sep 8, 2015 05:53 AM
