Headlight Relay (2k2)
Old Jan 26, 2015 | 06:03 AM
eyeball187's Avatar
Does anyone know where the headlight relay is located on the 2k2? I don't have the owners manual and I tried to google it. But, no luck. Thanks in advance!
Old Jan 26, 2015 | 08:40 AM
colt149's Avatar
LH headlamp (low and high beam)
does not operate, but RH headlamp
(low and high beam) does operate:
1. Check 20A fuse (No. 54, located in fuse and fusible
link box). Verify battery positive voltage is present at
terminals 1 and 6 of headlamp LH relay.
2. Check headlamp LH relay.
3. Check harness between headlamp LH relay and
smart entrance control unit.
4. Check harness between smart entrance control unit
and lighting switch.
5. Check smart entrance control unit. (EL-350)
RH headlamp (low and high beam)
does not operate, but LH headlamp
1. Check 20A fuse (No. 55, located in fuse and fusible
terminals 1 and 6 of headlamp RH relay.
2. Check headlamp RH relay.
3. Check harness between headlamp RH relay and
Read this:http://www.nicoclub.com/FSM/Maxima/2002/EL.pdf
EL-37
Old Jan 26, 2015 | 10:09 AM
DennisMik's Avatar
See page 449 in the above link for a larger picture.
Swap the left and right relays and see what happens. If you have a Canadian Maxima, the daylight running module could also be the problem.
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Oct 28, 2019 10:58 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
