LED Exterior bulbs
LED Exterior bulbs
I've been thinking about changing out my brake, signal, reverse, license plate lights with LED's. I see Philips has a new line of direct replacements for 7443, 7440's, etc. Anyone use these and have pics? Does anyone know if you still have to put a resister in the brake lights with these? Let me know anyone's experiences with these.
I'm glad you started this thread, because I've been wanting to switch my turn signals, brake lights, and reverse lights over to LED's and wasn't sure if they could be directly replaced or any special wiring needed to be done.
Anyone out there have before and after pics? Any experience with these off the shelf Philips bulbs or any other? Any advice on colour of LED's (by this I mean do you use a white LED for a brake light when it is behind a red lens or a red LED). As you can tell I don't have much experience with these although I have done my cluster and interior. Exterior bulbs seem to have multiple configurations for the same bulb. For example superbrightleds has 13 different configurations of 7443 bulbs. Point me to a post if I'm missing one.
I'm running these in my tails:
Also using Philips leds in licence plate lights and corner/running lights. I like them very much.
The design of the brake bulbs with that shield on top makes it so you don't see the outline of the bulb (unlike halogen bulbs)
And here you can see how those bulbs in the tails compare to my led side markers.
The bulbs will work just fine in your tails but you will have no cruise control unless you add a resistor
Also, you want red color bulb for the brakes.
So if system senses brake light problem, it will not let you set cruise. Sucks.
That makes sense. Guessing it's the same for the 5.5? How big of a resistor it's needed?
Side markers had no issues, and no resistors.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
