Behind dash light sizes
Old Jan 24, 2002 | 01:57 PM
zman187's Avatar
I tried searching but i didn't find anything on this... Does anyone know the sizes of the dash bulb's that are behind the guages..i have heard 194 wedge but I just want to make sure. I have a 2k SE
Old Jan 24, 2002 | 02:33 PM
BigDogJonx's Avatar
Re: Behind dash light sizes
They are not 194 bulbs, they are smaller. I forget what number.
Old Jan 24, 2002 | 06:22 PM
zman187's Avatar
Also how hard is it to take the dash off... and if I got lets say red, would i still be able to see it or would i not be able to see the numbers. Just tell me what you think
Old Jan 24, 2002 | 07:34 PM
emax02's Avatar
Re: Re: Behind dash light sizes
If it's the same as the 4th..and I think it is, then it is "194" wedge.
Old Jan 24, 2002 | 09:38 PM
2k1maxgle's Avatar
dash lights......
i think it would be tight to change them to oh...say...blue....i want all my interior lighting to be blue, but anyway...how hard is it to remove the dash and get to the bulb??? and what size is it for sure????
Old Jan 26, 2002 | 10:15 PM
theMax's Avatar
Check the wattage! I think it looks like a 194 but someone tried that and blew some fuses. Try the search, I couldnt find the thread.
Old Jan 26, 2002 | 10:55 PM
BigDogJonx's Avatar
Acutally make sure the wattage is correct not cause of the fuse, but of heat problems. If it is a 2watt bulb, dont put a 5watt bulb. My DAD did this in his Mercedes (yes my dad started modding) and he burned the socket and the whole surrounding plastic with the 5watt bulbs that he put in there on the speedometer cluster and ended up having to buy a whole new one for over $1000.
Dixit
Old Jan 26, 2002 | 11:16 PM
D Love's Avatar
Ok, for a 2k2 SE, there are two different bulbs for the instrument cluster. There are three of the "A" type bulbs. These are 14V-1.4W. There are four of the "B" type bulbs. These are 14V-3W. For the control unit (Air conditioner, heater...) There are two bulbs, but I don't have the specs on them. Sorry, I don't have any info about what "size" the bulb is (such as 194). I just have the part numbers that Nissan uses when they order them (if you went through your dealer to replace the stock ones). I don't know if the 2k's and 2k2's have the same setup.
Old Jan 27, 2002 | 02:03 AM
JKiMaxAC's Avatar
i think there 164's i'm not sure tho.. cuz aren't the 99 maximas like that to??
Old Jan 27, 2002 | 06:50 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
164=194 but i want to change mine to like blue ones though. anyone have ideas.
Old Jan 27, 2002 | 09:48 AM
2k1maxgle's Avatar
yeah i wanna change mine to blue too.....how hard is it to get to the bulbs to change them????
Old Jan 27, 2002 | 12:19 PM
JKiMaxAC's Avatar
some one should try and change the bulbs with wide angle LED's i think that'll look bad @ss
Old Jan 27, 2002 | 01:06 PM
theMax's Avatar
what is a "wide angle" led?
Old Jan 27, 2002 | 01:07 PM
BigDogJonx's Avatar
Re: ....
I attempted to open the speedo cluster unit and got all the way to where I had the unit off and got the front clear plastic off, now you got the raw 4 gauges there. They cannot be removed because first the NEEDLE for each gauge has to be removed. That is the hardest part if you want to change some bulbs that might be imbeded behind there.
But for th most part all of the bulbs are in the back of the unit, all you need to do is take off the whole unit and on the back there are turn sockets for each bulb.
Dixit
Old Jan 27, 2002 | 05:04 PM
zman187's Avatar
Sounds like too much work for a mod that won't do much for the interior questions on the 5th gen the side markers are the same size as the door lights i dont' know about the center light on the celing or the reading lights
Old Jan 27, 2002 | 08:41 PM
JKiMaxAC's Avatar
A wide angle LED is just a normal LED but the viewing angle is wider.
But for the 5th gen's the blubs that light up the gauge cluster. Dose ne one know wut it looks like?? is it a wedge bulb? Or is it attached to plastic clip, so the bulb and plastic r one unit?
Old Jan 27, 2002 | 08:45 PM
we are trying to determine that.
Old Feb 22, 2003 | 11:12 PM
chinaonnitrous1's Avatar
well...whats the deal, im about to rip out my gauge cluster...i guess i'll hafta check this out myself...
Old Feb 16, 2022 | 09:46 PM
BigHawk's Avatar
No
There not 194 wedges I used those however just used a different approach
Old Feb 19, 2022 | 09:03 AM
The_Fixer's Avatar
#74 bulbs
Old Jul 5, 2022 | 02:58 AM
Sudsy's Avatar
so what did you end up using,
And where did you order the lights from?
mvm062
Nov 30, 2020 09:00 AM
AnsonJ
Jun 2, 2017 01:35 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
maximaham
Aug 20, 2015 10:23 AM
