2000 maxima flywheel question
Old Mar 11, 2015 | 11:16 AM
thatcollegestudent's Avatar
The flywheel for a 2000 Maxima is a single mass flywheel correct? The Luk flywheel part number:LFW266 should be a good replacement for the stock flywheel? Thanks in advance
Old Mar 16, 2015 | 04:28 AM
Can someone please help?? im desperate. I am a complete noob with all this stuff.
Amazon.com: LuK LFW266 Flywheel: Automotive Amazon.com: LuK LFW266 Flywheel: Automotive
This flywheel says it will fit on my 2000 maxima. But when i look at the nissanpartsusa store and search online for the part number, the picture is so much more expensive and the picture is completely different from the Luk flywheel that it claims fits onto my car.
http://m.ebay.com/itm/321621760832?_mwBanner=1
Please help. I am so lost. Which flywheel do i go with. I dont want a fidanza. Thanks for the input guys
Old Mar 16, 2015 | 08:00 AM
Derrick2k2SE's Avatar
I believe that piece from amazon is a replaceable friction surface for a Luk flywheel. Not the whole thing. If you had worn out a Luk flywheel you could replace the worn friction surface with this.
Unless you already have a Luk flywheel that will do you no good.
Old Mar 16, 2015 | 08:03 AM
Unless the flywheel is really damaged you should be able to have it resurfaced by any machine shop for a very reasonable price. It's very easy on a single mass flywheel like you have.
Old Mar 16, 2015 | 11:12 AM
Thank you. I was wondering why it looked so different. I guess the price was too good to be true lol
Old Mar 16, 2015 | 09:37 PM
Why are you replacing it?
Old Mar 17, 2015 | 04:42 AM
To be honest, not quite sure LOL. I am purchasing the car from my uncle and i figured since im already going to be replacing the clutch, i should do the flywheel too. But instead i'm going to have my mechanic look at it first, and if it could be rearufaced than i will definitley just do that
Old Mar 17, 2015 | 05:22 AM
It should be able to be resurfaced. The clutch in the 3.5 liter cars is hard to cut and many machine shops wont touch them. Yours should be no problem. somewhere around $50 to cut it.
Old Mar 17, 2015 | 09:08 AM
ok thanks for the input
kenc15
Sep 25, 2015 06:38 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
