Touch the gas pedal & she dies
Old Mar 14, 2015 | 04:47 PM
mbs xk8's Avatar
Hey All...
Newbie Maxima owner here. I have a 2000 that I'm bringing back to life. She sat for a while. I've changed oil and gas, and belts and pulley.
When I start her up... she'll idle just fine, but when I touch the gas pedal, she tries to stall and die. If I'm very careful, I can gently get her to idle up to about 3k rpm, but if I'm aggressive with the gas pedal, she'll try to die.
Any ideas?
She has 200,000 miles, but is in good condition. I'm going to clean the Throttle Body and the IACV tomorrow. Have new gaskets arriving at the dealer Monday.
I really appreciate any advice you have.
Thanks!!
Old Mar 14, 2015 | 04:55 PM
The first thing to check is to make sure the MAF is plugged in.
Have you checked for codes?
Old Mar 14, 2015 | 06:59 PM
mbs xk8's Avatar
I've check for error codes and there aren't any.
Old Mar 15, 2015 | 05:03 PM
mbs xk8's Avatar
So I took the car out for a spin in a parking lot. She tries to accelerate but just can't. Ive cleaned the Throttle Body and the MAF.
Any ideas? Could this be the IACV?? I'm leaning in this direction.
Thanks!
Old Mar 15, 2015 | 05:11 PM
Could be the IACV. Maybe even the TPS sensor as well.
Old Mar 15, 2015 | 06:13 PM
nestorlugo's Avatar
Thanks!
Take out the ecu and check for the burnt (staxxx) chip...if not buy a new maf only $77+ at courtesyparts.com
Old Mar 15, 2015 | 07:16 PM
D.Stillwell's Avatar
Could be MAF, fuel, or exhaust restriction.
I would actually say IACV is less likely since you said it idles fine, bad IACV would cause idle issues.
Old Mar 15, 2015 | 08:59 PM
mbs xk8's Avatar
Thanks for the help. Any pictures of the burned chip? I need to research how to remove the ECU and look at it. I'm new to the Maxima world. I've been working on MB's for years.
WHere is the ECU located?
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
