Advice for 2003 Maxima Compressor
Old Mar 18, 2015 | 04:38 PM
gwmac's Avatar
I just replaced my alternator and also hub assemblies and thought I was done with repairs for a while but now my A/C is kaput. Here in middle Georgia it is already AC weather so need to get this done soon.
I took it back to the same independent mechanic that installed the hub assemblies and he gave me a quote of $650 parts & labor. He ran some tests and the compressor wouldn't come on at all and he said it needs to be replaced.
His quote was for parts and labor and he said I would need to buy the whole compressor assembly kit. I saved a lot of money by buying a new alternator and hub assembly myself and letting them install only.
From my research I am leaning towards the Denso.Part # 4715008 RockAuto is selling it for $205.79 which is a lot cheaper than what the local Nissan stealership quoted of $570 for the compressor alone.
If you had a 2003 Maxima would you go with that Denso? I saw a few other brands but wanted to ask you guys if that is a good choice. I think it is OEM? not sure though.
Second question is the independent mechanic said if I bought my own parts for him to install I would need the whole installation kit. At the checkout portion of Rock Auto I saw this message
"Warranty requires you to replace the A/C Expansion Valve or A/C Orifice Tube (depending on the vehicle), as well as the A/C Receiver Drier / Accumulator (On some vehicles this is part of the A/C Condenser)."
So for my Maxima, I need the valve not tube right? Then I need the A/C receiver Drier/Accumulator. Is it also a good idea to get the A/C System O-Rings, Seals, & Gasket Kits? I just want to make sure I order the right parts.
The mechanic said he couldn't warranty the parts if I bought them myself only if he used his parts. I forgot to ask him his parts price alone but is $650 a decent estimate? Not sure how many hours of labor for this job. I will check some other shops tomorrow but I was just hoping to get some ideas here.
The parts themselves include a warranty though just not sure if $650 is on the high or low side. Looks like if I buy the parts myself I am looking at around $235 but I have no idea how many hours of labor is typical for this job.
I got a lot of great advice for my alternator and hub assembly which saved me a lot of money so hoping you guys can help me once more time.
Old Mar 18, 2015 | 04:47 PM
nestorlugo's Avatar
Take it to a place that charges like $35.99 to inspect the a/c system, you may just need freeon
I don't know about my maxima but on my zukitron(Suzuki) the clutch doesn't engage when the freeon is low or empty...
Old Mar 18, 2015 | 05:39 PM
gwmac's Avatar
That is where I was earlier today when I got the $650 quote. They said the freon was low and even put some new freon in but the compressor never came on even after that. We sat that a good 5 minutes with it running just to make sure. It just blows warm air.
Old Mar 19, 2015 | 09:17 PM
DennisMik's Avatar
OK, assuming the repair shop put in the proper amount of refrigerant (it is not Freon, it is R134A), then possible bad parts are:
Refrigerant pressure switch
Magnetic clutch on compressor and/or fuse
Compressor
And with lesser probabilities:
Ambient temperature sensor (if auto climate control)
a/c relay
a/c auto amp (dash control panel)
Old Mar 20, 2015 | 11:11 AM
gwmac's Avatar
Compressor
a/c relay
Thank you. That really helps. I am going to a different shop sometime soon that specializes in Car A/C and hope they are a bit cheaper. I will research all those items you listed and be better prepared to haggle with them now. Much appreciated.
District
Aug 15, 2015 08:23 PM
wingsfan24
Aug 15, 2015 07:35 PM
Flores94
Aug 11, 2015 12:53 PM
09maxshawn11
Aug 9, 2015 01:13 PM
