In dyer need of help asap
Old Mar 18, 2015 | 04:47 PM
carlosvq30's Avatar
Well i was doing a tune up and changing my spark plugs when one of the coil pack bolts broke in half. Its pretty flush so i couldnt secure my coil pack which left me with a misfire
So i tried using a screw extractor to get it out and that just turned into a nightmare What should i do ? And also since my manifold is apart is it safe to spray throttle body cleaner to clean it
[img=http://s30.postimg.org/npf9dl8hp/image.jpg]
[img=http://s30.postimg.org/3tj9y1rgd/image.jpg]
Old Mar 18, 2015 | 04:49 PM
Fakie J Farkerton's Avatar
Needle nose and prayer.
If all else fails I would pull the vc to expose more of it, but that's last case.
Old Mar 18, 2015 | 04:55 PM
nestorlugo's Avatar
Cut a slit with a angle grinder and a thin disk to use a flathead
Old Mar 18, 2015 | 06:00 PM
Child_uv_KoRn's Avatar
Bad *** Newb
*dire
Old Mar 18, 2015 | 06:13 PM
ateick's Avatar
Doesn't look too bad. Get a good bit and drill it out. Realllly slowly. Then get out the tap and die set if an extractor won't work.
Old Mar 18, 2015 | 07:42 PM
carlosvq30's Avatar
is it tappable ?
Old Mar 18, 2015 | 10:50 PM
Plug the nearby tube with rags.
Grab a punch and a hammer and hit dead center on the broken bolt. Then start with a very small drill bit. Then move up to the next size bit. Then the next size. As you approach the size of the bolt, it will basically disintegrate when it gets super thin. Then extract with needle nose pliers. Vacuum the shards out. If done right, you won't even affect the threads or need to re-tap it or do anything. Very simple to do, just a test of patience really.
Old Mar 19, 2015 | 07:34 AM
carlosvq30's Avatar
Plug the nearby tube with rags. Grab a punch and a hammer and hit dead center on the broken bolt. Then start with a very small drill bit. Then move up to the next size bit. Then the next size. As you approach the size of the bolt, it will basically disintegrate when it gets super thin. Then extract with needle nose pliers. Vacuum the shards out. If done right, you won't even affect the threads or need to re-tap it or do anything. Very simple to do, just a test of patience really.
thank you going to trybit today
Old Mar 19, 2015 | 02:45 PM
FanaticMadMax's Avatar
ouch sorry to hear that, hopefully you got a good extractor bolt to get that sucker out.
Old Mar 19, 2015 | 05:56 PM
zenjia 03merlot's Avatar
These most likely not work but less invasive, but if you have a magnet that cylindrically narrow enough to just magnetize the broken bolt and not the surrounding die. Maybe you can try to superglue/super metal adhesive the broken bolt to something with more grip leverage.
worse comes to worse, drill it out. if the threads are messed up, just tap a die yourself, too easy.
Yeah, clean up the Intake Manifold with clean, throw-away rags sprayed with brake cleaner or other solvent, then wipe off paying especial attention to throttle body area, like don't touch it with any force. I sprayed the cloth first, it made it much easier for me.
Old Mar 19, 2015 | 06:20 PM
ac max 92's Avatar
If you have a mig welder the easiest way would be to get a nut and weld the inside of the nut to the broken bolt then you can remove it with a socket. This method also works well on broken manifold studs especially when you have aluminum heads when heating it up won't help.
Old Mar 19, 2015 | 08:27 PM
Did you look at the pictures? That's a great idea, but there is no way that your suggestion is even remotely applicable in this situation.
Old Mar 19, 2015 | 08:31 PM
ac max 92's Avatar
Agreed. A little too small. Looks like a job for either a small easy out or drill bit.
Old Mar 19, 2015 | 08:38 PM
nestorlugo's Avatar
Every one pitch in a dollar let's give this man a used vc....
Old Mar 19, 2015 | 09:02 PM
That won't work either.
Old Mar 20, 2015 | 03:12 AM
BronxSleeperMax187's Avatar
7 dollar tube of auto silicone, let dry over night, cheap easy fix. Put A small amount the size of A peanut where you stripped the bolt and press firm, find something to put weight to hold it firm over night, tell the mechanic that wants 175 dollars forget it lol....unless you got tools and drills
Old Mar 20, 2015 | 08:09 AM
4thGenTuner's Avatar
JFC.
Either get an easy out or swap the valve cover.
This isn't rocket surgery or brain science.
Old Mar 20, 2015 | 10:19 AM
Originally Posted by 4thGenTuner
JFC.
Or rocket science or brain surgery either.
Old Mar 20, 2015 | 11:43 AM
You know, I misread the OP.
I was thinking it was the coilpack that broke. Whoops.
Just replace the vc.
Old Mar 20, 2015 | 11:45 PM
Drill that baby out, piece of cake.
Any update OP?
Old Mar 21, 2015 | 03:52 AM
carlosvq30's Avatar
Drill that baby out, piece of cake. Any update OP?
yeah lol replaced vc. And next project now i put everything back together and have a vaccuum lake thru intake manifold :/ lol
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
