HELP~DOOR PANEL REMOVE~~
Old Jan 24, 2002 | 10:58 PM
skyjay617's Avatar
guys, i was following the instructions in How To's, i unscrew everything and remove everything, but, i just can't pull it straight up, it's won't move....... i dont want to pull up so hard so my door panels won't be fxcked up, pls help me, thanks~~
Old Jan 24, 2002 | 11:25 PM
D Love's Avatar
Ok, now I'm not exactly sure about this, but I'm pretty sure. I just had an alarm installed in my Max this past weekend. After you take off the Windows/door locks controls, and take off the little seal around the door handle, you should be able to just pull outward on the door. The installer started popping off the door panel at the bottom of the door.
Old Jan 25, 2002 | 12:44 AM
skyjay617's Avatar
pls help~
......i still can't pull up.....i have a question though....did u see the installer use the screw driver to pop off the buttom of the door?? or just pull them up....?? thanks.....
Old Jan 25, 2002 | 01:11 AM
D Love's Avatar
he used a screwdrive to pop out the bottom. I don't think u should be pulling up, I am pretty sure they go out. But not certain.
Old Jan 25, 2002 | 06:09 AM
ispeed's Avatar
you need to pry the bottom off the door. there are clips that attached to the panel and the door shell holding it on. Once those are loose, you just pull straight up.
All you need to do is loosen one and you will see how easy it is to get all the rest of them free. Easy stuff! Take a flat head screwdriver and put it in between the panel and door shell. Pry up. Or if you plan on removing it often, go to autozone (or similar store) and get a door panel removal tool.
Old Jan 25, 2002 | 06:13 AM
soundmike's Avatar
Very sound, Mike
I had the same problem, for some reason that thing just sticks like glue unless you use the tool.
I cut myself trying to pry it up. Did the screwdriver tip as well to no avail. I must've been doing it wrong.
However when the pro installer did it i didn't hear any popping sound and he took it off pretty easily. Must've been using the tool.
Old Jan 25, 2002 | 08:27 AM
chris2001gle's Avatar
Buy the panel removal tool - it is well worth the few bucks that it costs. It looks like a screwdriver with a large flat angled blade with a slot in the middle. It will pop the clips right out without damaging the cover. When you use a screwdriver, you chance damaging the panel. I wrapped the blade of the tool with masking tape to prevent metal to metal contact when sliding it between the panel and the metal of the door.
Old Jan 25, 2002 | 01:35 PM
ispeed's Avatar
smart move!
Old Jan 25, 2002 | 01:37 PM
ispeed's Avatar
there are blue compression (at least that is what i call them) that are attached to the door panel itself. These clips then slide into holes in the door skin that hold it on from rattling. Once you figure out where they are and release the first one, it will take you all of 2 minutes to remove the panels. Easy.
ef9
Sep 29, 2015 11:29 PM
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
carid
Sep 17, 2015 05:00 AM
