Which Oil Catch Can from eBay?
Old 04-09-2015, 07:26 AM
george__'s Avatar
Prices range from $30 - $300
Which is the one to get for the SeXima?
george__ is offline
Old 04-09-2015, 07:42 AM
VMS was what I was going to run. I liked their baffled design. Price isn't bad either.
ChrisMan287 is offline
Old 04-09-2015, 07:47 AM
george__'s Avatar
This?
http://www.ebay.ca/itm/VMS-ALUMINUM-...a7e0ed&vxp=mtr
george__ is offline
Old 04-09-2015, 12:47 PM
^ Yup. I think Javon had one.
Old 04-09-2015, 01:01 PM
03maximaguy's Avatar
Originally Posted by george__
wouldn't the breather on that can allow air that's not metered into the intake?
03maximaguy is offline
Old 04-09-2015, 01:52 PM
Fakie J Farkerton's Avatar
You are correct.
Fakie J Farkerton is offline
Old 04-09-2015, 02:06 PM
dot dot dot ...
NmexMAX's Avatar
Always a good read ...
http://www.infinitiscene.com/forum/t...-Air-separator
NmexMAX is offline
Old 04-10-2015, 08:27 AM
Get Off My Lawn
Chris Gregg's Avatar
I've used several of the ADD-W1 cans. You can get them on ebay. I found an auction that had an OBO option, so I made a lower offer with buying three cans. They are attractive, have proper size ports, have a "dip stick," have an internal baffle, shallow design for easy installation almost anywhere, and a collector can that unscrews for easy oil removal.
I have one on my '03 Max and on my '04 Quest. I will likely put the other one I have on my '89 Max.
Chris Gregg is offline
Old 04-10-2015, 01:09 PM
ateick's Avatar
Originally Posted by Fakie J Farkerton
You are correct.
What do people do - cap off the breather?
ateick is offline
Old 04-10-2015, 05:13 PM
If you're NA you just don't buy that one.
If you're FI, you buy it.
Old 04-10-2015, 06:26 PM
george__'s Avatar
Which one mr.Fakiee
george__ is offline
Old 04-10-2015, 06:38 PM
barristan's Avatar
I just bought one of these a couple of days ago. $83. Should hold a bit more oil than the ghetto Home Depot setup i have now.
barristan is offline
Old 04-10-2015, 09:25 PM
Black Lion
maxprivate's Avatar
Try out SaikouMichi oil catch cans. He can custom make a catch can for you if needed. Prices are very reasonable as well.
I purchased a dual catch can: 1 for front VC and 1 for the intake manifold. If you're NA you shouldn't be seeing any oil getting in your manifold.
In addition, that oil catch can from Ebay looks like it is venting not bringing air in.
maxprivate is offline
Old 04-10-2015, 10:15 PM
schmellyfart's Avatar
Originally Posted by maxprivate
Try out Saikou oil catch cans. He can custom make a catch can for you if needed. Prices are very reasonable as well.
In addition, that oil catch can from Ebay looks like it is venting not bring air in.
Came here to recommend saikou michici, customizable, welded, and about the same price as these ebay cans.
schmellyfart is offline
Old 04-10-2015, 10:26 PM
george__'s Avatar
It's way more...
They want $95 plus mods and whatnot
http://www.saikoumichi.com/s1_oil_catch_can.html
george__ is offline
Old 04-10-2015, 10:41 PM
Black Lion
maxprivate's Avatar
It's way more...
I wouldn't say "way more" plus you get what you pay for. SaikouMichi also can give you optional relocation valves with hoses: you can relocate The drain valves easily. I picked those up as well.
Just passing on info of a quality product. But hey if you want EBay then suit yourself.
Old 04-10-2015, 10:50 PM
george__'s Avatar
What exactly do I need for optimal gen 5.5 setup from Saikou?
george__ is offline
Old 04-11-2015, 05:44 AM
Black Lion
maxprivate's Avatar
Read the link Nmexmax posted. Some good info there for your knowledge.
Contact Saikomichi, he can help you set up the most appropriate system for your application. A dual catch can is best or 2 separate ones: For front VC and PCV system ( in particular for 4th gen application) this way any escaped oil is routed through both OCCs individually.
Old 04-11-2015, 07:13 AM
Which one mr.Fakiee
It comes with a bolt that you can use to plug the breather hole. Look at the pictures.
Old 07-01-2015, 08:54 AM
justben's Avatar
Can someone post a diagram of how to install one (single not dual) on a 1998 VQ30? THANKS!!!
justben is offline
Old 07-01-2015, 09:22 AM
RealityCheck's Avatar
Bought a $60 eBay can that had an optional breather filter on it. Interior design was horrible and couldn't even fit the plastic tube in it for the oil to enter through. Didn't matter because I just capped off my intake port and left the breather filter on for the PCV. You might see them when browsing through. They vary in different colors.
RealityCheck is offline
Old 07-01-2015, 08:31 PM
WTF?'s Avatar
If it is open to atmosphere.....breather on top.....it's worthless, and completely non functional. Must pull a vacuum to work.
WTF? is offline
hcarter1112
42
07-18-2022 03:35 PM
06-06-2017 02:01 PM
Fbana41
08-29-2016 12:18 PM
220k+ A32
25
10-03-2015 09:09 PM
DBear
09-14-2015 08:33 PM
Quick Reply: Which Oil Catch Can from eBay?
