lower control arm question
Old May 7, 2015 | 03:53 PM
uptownsamcv's Avatar
I was installing the E.S. bushings on my lower control arms today and noticed that the hole where the sway bar link connects wasn't a regular hole but an elongated hole.
i only noticed it cause it was loose on the control arm end on the driver side.
Old May 7, 2015 | 06:02 PM
nestorlugo's Avatar
That's more like a statement rather,not a question!!
But if you're asking if it's normal than the answer is yes..!!!
Old May 8, 2015 | 12:55 PM
FanaticMadMax's Avatar
My sway bar link doesn't have an elongated hole. I'm not sure what bushing you're talking about since sway bar link do not have replaceable bushing.
Old May 8, 2015 | 12:58 PM
Daniel VQ30life's Avatar
i think he means where the sway link attaches to the lca
I love my A32
Old May 8, 2015 | 03:09 PM
I love my A32
you must have read it too fast. I changed out the LCA bushing but noticed that the hole for the sway bar linkage is long instead of a circle.
Old May 13, 2015 | 11:02 PM
import_killer's Avatar
Sounds like over time loose or worn end links have elongated the hole vertically. Not a big deal as long as the end links can be tightened and do not become loose overtime. If they do loosen several times after you have tightened them more then once or repeatedly, you'll have to get really creative to secure it or just replace the lca. My .02.
Old May 14, 2015 | 11:58 AM
The_Fixer's Avatar
No thats what oem endlink mounts look like oblong holes
Old May 14, 2015 | 12:00 PM
The_Fixer's Avatar
If you would of Searched you would of seen that people use hardened washers on either side to prevent it from moving.there is a Suspension thread that has everything you need to know in it.
Old May 14, 2015 | 12:15 PM
I seem to notice less nose dive when stopping and a tiny bit more understeer...
Matt93SE
May 24, 2019 02:58 PM
maxocar
Aug 21, 2015 12:57 AM
AT978
Aug 15, 2015 06:39 PM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
