Both headlights stopped working.
Old May 20, 2015 | 03:33 AM
00 Max's Avatar
Either manually turning them on or auto I just have fogs & park lights. High beams do work. Is there a fuse, relay or is it the switch (I hope not).
00 Maxima se
Old May 20, 2015 | 03:58 AM
1996blackmax's Avatar
It seems unlikely that both headlights would go out at the same time. i would check the fuses/relays first to make sure that they are ok.
BronxSleeperMax187's Avatar
Start with A replacement light for now to see if that works... then get back to us.
Old May 20, 2015 | 05:36 AM
TDotMax's Avatar
Are you in Canada? Reason I ask is the DRL module would most likely be the issue. Had this happen to me.
Old May 20, 2015 | 07:08 AM
DennisMik's Avatar
It is not a relay or fuse because the same parts power both high and low beams.
In a USA car, check the bulbs first but it is probably the headlight switch.
In a Canadian car, the DRL module is #1 suspect, then the headlight switch.
Old May 21, 2015 | 12:40 AM
00 Max's Avatar
Ugh, thanks guys. USA car and I will hav it checked Saturday.
Old May 23, 2015 | 07:05 PM
00 Max's Avatar
I ended up needing both bulbs. I don't know what happened but glad it was an easy fix.
Old May 23, 2015 | 10:41 PM
DennisMik's Avatar
Glad to hear it wasn't anything major.
Kind of unusual for both bulbs to go out same time. This is a great example of checking the simple stuff before jumping into the heavy duty stuff.
Old May 24, 2015 | 12:40 AM
That's good to hear. Easy fixes are always nice
Old May 25, 2015 | 08:37 AM
00 Max's Avatar
Thanks guys, I was expecting a fuse or a relay. I was surprised good bulbs are $30 a pair.
doctorpullit
Oct 28, 2019 10:58 PM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
