P0403 after ecu swap
Old May 30, 2015 | 06:20 PM
avin's Avatar
I believe I was sold a 2000 ecu since I have a p0403 code on my 2001 after doing an iac and ecu swap.
It revs only till 2800, then you have to stall it and it drives mint again.
Is it true that 2001's dont have egrs?
Thanks!
Old May 30, 2015 | 08:37 PM
maxiiiboy's Avatar
Your profile says you have a 1999 Maxima, you refer to "my 2001" and to "2000 ECU". Very confusing. If you want help, you better clean up your communication.
Old May 31, 2015 | 02:59 AM
DennisMik's Avatar
Some early production 2001 did, but most don't.
On cars that have EGR, getting a code like P0403 will cause the ECU to go into safe mode. The rpm will be limited to 2800 rpm.
But I don't think that an ECU designed for an engine without an EGR will throw the P0403 code.
Old May 31, 2015 | 07:38 AM
avin's Avatar
I just bought a 2001 also since my 1999 is immobilized and has a few other issues...
Old May 31, 2015 | 07:40 AM
avin's Avatar
hmm.. I'd imagine it'd throw the code because it has no egr...??
and yes its in safe mode, if i stall it and start instantly it comes out of safe mode for some reason
Some threads say its because of the ecu/no egr combo. Others say its because of a bad egr?
Old May 31, 2015 | 09:24 AM
DennisMik's Avatar
I got the years of the cars/ECUs backwards. A 2000 ECU is looking for the signals from an EGR. Since your engine probably doesn't have the EGR, the ECU will throw the code.
There are so many places that don't really know the differences between the years of the Maximas. They look at the body style and say that a part fits all years. E-bay has to be the worst place for stuff like this.
You probably do have the wrong ECU. Return it. If you still have your old ECU, look at the numbers that are on it and compare them to the one you got.
Old May 31, 2015 | 09:12 PM
avin's Avatar
THANK YOU!
I bought it locally and he said its from a 2001, but I really dont believe him at this point...
I'll probably be able to sell it?
and I'll have to send my old ecu to get repaired I guess because I need to get through emissions test asap
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
