Cooling system upgrade
I don't think you are going to find something "performance" radiator and hoses. etc... but I do know this you can add something called Wetter Water, or Royal Purple Cooler, which basically an additive to your anti freeze and it "wets" the metal parts and cools the temp lower by much as 15-20 degrees. Not sure if that's something you're looking for.
here the thing, you definitely won't find a lower thermo stat temp since they are part of the water outlet assembly, I have not seen anyone carries a lower temp t-stat all you can find is OEM Temp
, Z33's have a lower opening temp, and there's always the Nismo unit, which is even lower. Or you can modify your stock unit as people have done in the past. Couple that with having a manual switch to your fans and there's your 10$ upgrade.https://maxima.org/forums/general-ma...-temp-mod.html
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
