01 maxima AC not blowing cold
Old Jun 6, 2015 | 12:26 PM
Trin1j23's Avatar
Today I evac my AC system I rented the machine from autozone. After it was finishing I added 2 12oz cans of freon. While putting it the compressor engaged and the air wasn't getting cold at all even after adding both cans. The air was blow cold jus before I evac the system. The reason why I evac the system is because I had changed the compressor 2 months ago and I didn't evac it at that time so the air wasn't as cold.
Old Jun 6, 2015 | 01:06 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You should have just purged the lines. You don't have to vac it to make it ice cold.
You need gauges.
Old Jun 6, 2015 | 01:22 PM
Trin1j23's Avatar
You need gauges.
Oh ok so do u kno what might be the problem that it's not blowing cold now
Old Jun 6, 2015 | 04:15 PM
Bad *** Newb
There's no way to know. You need to be able to see the pressure of the high and low sides.
Is the compressor even kicking on?
Old Jun 6, 2015 | 05:33 PM
Trin1j23's Avatar
Yes the compressor is kicking on and the fans is also on
Old Jun 6, 2015 | 08:24 PM
mclasser's Avatar
AC work should only be attempted if you actually know what you're doing. If you evacuated the system (properly that is), you need to add back the EXACT amount of refrigerant spec'd for the system using a scale. Too much refrig. is just as bad as too little. You may have a leak somewhere that UV dye can find. Is the compressor OEM?
Like Child uv korn said, you need gauges.
Old Jun 7, 2015 | 07:35 AM
Trin1j23's Avatar
I took the car to get checked the low 25 and high 150, the shop told me that I need a compressor
Old Jun 14, 2015 | 02:44 PM
Trin1j23's Avatar
I ended up just changing the expansion valve and that was the problem why the AC wasn't blowing cold.
Old Jun 14, 2015 | 11:05 PM
cdoublejj's Avatar
This my dad does this on the side and more often then, it needs evacuated, or there is leak or it's OVER or undercharged. that's another thing it can be overcharged.
while i'm here whats up the 60F limit on the maxima? i wonder if it's possible to make it colder? (doub it) :P i heard the chrysler imperials could put frost on the vents back in the day. lol
EDIT: is the expansion chamber a common maintenance item?
Old Jun 16, 2017 | 12:36 PM
Maximer02's Avatar
I started replacing least expensive items. Schrader valves then o-rings. Did the expansion valve, temp was blowing 70F and now blows 45F after refilling R134.
Old Jun 16, 2017 | 02:38 PM
FanaticMadMax's Avatar
everyone's statement is correct, that whenever you replace the compressor, always recommend to replace your drier and expansion valve. Why? because you don't know why or how did the a/c compressor quit working, was it due to metal shards inside blew? or was it lack of lubrication from not using your a/c at all, then end up dry run then seized the compressor? so those are good reason to replace the drier, that act like a filter, that remove debris and moisture. The expansion valve, or like some cars have orifice tube instead, that regulate the temp of the refrigerant. So good input guys. I work at a part stores, and customers do not have a slightest idea how an a/c work you guys on the other hand have done your homework and very well informed. Keep up the great input for our fellow org.
Old Jun 16, 2017 | 02:51 PM
maximatech12's Avatar
I thought one time I saw a guy charging a brand new car up with Freon right outside of the Auto Parts store! He was in front of me buying a whole can of it!
I thought Geez you know that's going to be traded in then a bunch of warranty work!
Old Jun 16, 2017 | 04:45 PM
DennisMik's Avatar
24 oz (2 12 oz cans) of refrigerant might be too much. The system takes between 21 and 24 oz, so try removing maybe 2 oz.
Lakersallday24
Nov 7, 2024 07:31 PM
cheftoo
Aug 20, 2015 05:17 AM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
