Timing Belt on 03 Max
Hi I all. After years of lusting, I finally purchased my own maxima. Recently when I crank the car up, Im hearing the squeaking noise. From being a gear head I know this is the timing belt, however I knew that all maximas, 95 and up have timing chains. When I peeked under the hood yesterday I noticed that I have a timing BELT. I am thoroughly confused. Any suggestions?
The timing chain is covered. The belts you see are driving the accessories, steering, ALT, AC etc.
Download your FSM so you know exactly what's going on with what.
http://www.boredmder.com/FSMs/Nissan/Maxima/
Start up squeaks are usually from the alternator belt, as the alternator has extra load on it from charging up the battery. Try tightening it up if there are no visible cracks/damage. If that doesn't work, replace the belt. Also check all the pulleys for play and clean off any grease on them.
Also on the 03 maxima if you change your serpentine belt and still get the belt noise you may want or need to replace your belt tensioner pulley. On my 03 the tensioner pulley was failing and my belt was out of alignment by just a little bit. It was enough to make every new belt squeal no matter what I did.
Part is cheap too. Like 35$. I think I might even have an extra one lying around.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
