Killed a Passat...
Old Jan 26, 2002 | 08:37 AM
doublea's Avatar
Killed a Passat...
Hey guys, yesterday I was coming back from the office around 6:00pm, I was driving normally not speeding, anyway I was waiting at the red light and sudently I see 2 cars coming fast, a Passat and and Intrepid, so I am on the left lane the Intrepid is on the middle lane and the Passat on the right lane, I clearly see that those 2 guys look like nervous and anticipating the green light, revving their engine and started a fraction of a second before it turn green, so I decided to let them take a bit of advance on me like 1/2 car length, but few second after, I decided to punch it, manually shifting my auto, as soon as I hitted the 2 nd I took like a car on the Passat, the Intrepid was already few cars back, the Passat guy really wanted to take me, but then I shifted to 3rd and took another 1 or 2 cars over but he was really pushing hard, so after passing an overpass I had to merge in the right lane to take the acces road of a boulevard, and the Passat sticking in my Bu** cuz I slowed down so in the curvy access road I punch it again and this time it was bye bye sweety pie.
P.S: One thing I founded interesting on my Max when I manually shifted at WOT, the rpm went to 6500rpm without any signal from the rev limiter, I though that most max would hit the rev limiter at around 5900 - 6000rpm. Is it a commun situation, feed back would be appreciate.
Cheers
DoubleA
Old Jan 26, 2002 | 09:03 AM
zman187's Avatar
Good Kill
Old Jan 26, 2002 | 09:07 AM
02MaximaSE's Avatar
Re: Killed a Passat...
Cheers
DoubleA
well, doublea,
In my 2k2 automatic, I manually shifted while racing my friend, i put it all the way to 6600, and bumped into 2nd, I glanced back to look at my friend, and he was like 5 cars back , so I didnt realize while looking back that my 2nd would climb so fast, so i feel a pulse from the car, and look at the dash in horror, and see my rev's bouncing! at 7000 rpm!, the car shut down shortly afterwards and went into Limp mode ( no WOT, no 2300+ rpm revs, no over 35mph, NO 1ST GEAR!) I let it sit for 1 hr and it returned to normal, drove it now for 5000 miles since that happened and the car is running fine, actually got a better 1/4 mile time.. 14.7 - 14.6 now still stock
Old Jan 26, 2002 | 09:30 AM
soundmike's Avatar
Very sound, Mike
Re: Re: Killed a Passat...
Here's a tip when manually shifting, since there's usually a 3-500 rpm delay before the auto follows your command try shifting not at or close to redline but somewhere closer to 5000 rpm.
Why? Add in the delay and it'll shift right when the HP/Torque starts going down (Around 5.5k)
That way when you hit 2nd or 3rd you're right in the middle of the powerband where both Torque and HP is highest.
Since our engines seem to make most of it's power before hitting the highest rpm range (right before redline) it doesn't make sense to wait that long.
- Mike
Old Feb 1, 2002 | 11:31 AM
MaxSC's Avatar
Re: Re: Re: Killed a Passat...
- Mike
Hey when you have an automatic and take off from a stand still against someone what gear do you have it in, and do you leave the overdrive off or on?
thanks
Old Feb 1, 2002 | 12:42 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Re: Re: Re: Killed a Passat...
thanks
O/D off gets you about 10hp at the wheels.
Old Feb 1, 2002 | 02:34 PM
doublea's Avatar
thanks
Hey MaxSC, I always take off in 1st gear, I manually shift my auto tranny with O/D off. I tried what Hogan explained here and I agree, I tried it, I'd say it is probably the best rpm target for shifting( at least on my auto max, I cant speak for others though ) after 5500rpm the car kind of stall like the powerband is equal for sometimes.
Now I prefer to shift at that point and save the engine and tranny. Sometimes after warranty is over on my max, I'm going to have it rebuilt by Level 10 or someone here on the org that can take care of it.
Cheers.
AA
Old Feb 1, 2002 | 02:52 PM
SuDZ's Avatar
Another one bites the dust.
SuDZ
Balkins
Feb 1, 2016 12:45 AM
msellas
Sep 23, 2015 09:16 PM
hozay99
Sep 19, 2015 10:20 PM
Garrettz459
Aug 29, 2015 02:18 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
