Question: Outside Termometer Temps ?
Old Jun 20, 2015 | 10:55 AM
acw's Avatar
acw
Hey Buds,
I was wondering "How accurate" is the outside Temperature Thermometer ?
I see numbers on mine showing 96 degrees out...and was told that it is not accurate. HOWEVER, WHEN i double check the figures on Wunderground and Weather Bug, it seems to be pretty close.
What's your opinion ? ? ?
Old Jun 20, 2015 | 11:37 AM
Donkeypunch's Avatar
You can find where that weather station is and park your car next to the sensor maybe it's on the roof. see if it's accurate. being parked in the cool shade on your lawn or on a blacktop parking lot will effect temps by a decent amount.
Old Jun 20, 2015 | 02:42 PM
Child_uv_KoRn's Avatar
Bad *** Newb
It's always accurate to me. The exception is if you're getting baked on pavement/asphalt, but that's not the thermometers fault.
Old Jun 20, 2015 | 07:41 PM
DennisMik's Avatar
The temperature sensor is attached to the lower front right corner of the a/c condenser core. If I park on hot concrete, the temperature is too high until I drive the car for a bit. Then it seems to be accurate.
Old Jun 21, 2015 | 09:17 AM
acw's Avatar
acw
Dennis...hope all is well where you are!
Man...wouldn't that give off a Temp that is way hotter than outside?
I Mean its right next to the condenser...which is next to the Radiator ? ? ?
~T
Old Jun 21, 2015 | 09:53 AM
Bad *** Newb
~T
Not if you're moving...
Old Jun 21, 2015 | 02:27 PM
DennisMik's Avatar
~T
Like Child_uv_KoRn said, if you are moving, airflow is pushing all the heat from the condenser/radiator to the rear of the car, away from the sensor. The sensor does not respond that quickly to temperature changes, so you can stop for a red light and not see any fluctuation in the reading.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
