slow start issue
Old Jul 7, 2015 | 09:50 AM
02maxdd's Avatar
slow start issue
02 maxima 134k auto
My wifes maxima has developed a very slow start as of late.I have recently replaced
2 of the 02 sensors
New battery
New delphi fuel pump and filter
Both bank cam sensors
The oils thing lol ( by the oil cap)
Vias solenoid
I have not done the crankshaft sensor.
When I did the pump it came with a small liece of rubber hose. I didn't use it as I didn't know what ot was for.
Please help! I'm taking it to the dealer in 2 weeks when I leave for vacation. I'd love to avoid this if possible.
Old Jul 7, 2015 | 09:55 AM
foodmanry's Avatar
Da Roller Coaster!
Do a search...there is so much information on slow or hard start issues on 2k thru 2k3 Maximas it isn't even funny.
Old Jul 7, 2015 | 11:28 AM
02maxdd's Avatar
You are correct. I have searched and read so many threads. Most point to the cam sensors or occasiinaly the fuel pump. I've done both!
Old Jul 7, 2015 | 12:00 PM
foodmanry's Avatar
Da Roller Coaster!
Check your grounds. Some people have had success with added a ground wire kit.
Old Jul 7, 2015 | 12:13 PM
george__'s Avatar
crank shaft position sensor(s)
Old Jul 7, 2015 | 01:32 PM
Unclejunebug's Avatar
Fuel pressure regulator.
Old Jul 7, 2015 | 01:52 PM
foodmanry's Avatar
Da Roller Coaster!
Those are usually a no start if either isn't working. Not a slow start.
Check fuel pressure regulator. Forgot about that..:
Old Jul 14, 2015 | 06:59 AM
02maxdd's Avatar
How can I check the fpr? Do I just replace em?
Old Jul 14, 2015 | 08:03 AM
foodmanry's Avatar
Da Roller Coaster!
Check the factory service manual. Link is below...look in the FE (fuel, exhaust) section.
http://boredmder.com/FSMs/Nissan/Maxima/2002/
Old Jul 14, 2015 | 09:12 AM
I'm not sure there's anything you can do to check it's working properly. The link above to the FE section doesn't outline any troubleshooting steps. The part is not that expensive and if you're going into the gas tank I'd just replace it. It's a relatively easy thing to do. I had a similar issue that was solved by replace the FPR.
Old Jul 14, 2015 | 10:59 AM
foodmanry's Avatar
Da Roller Coaster!
Really? That's odd...usually you can check with a fuel pressure tester. Pressure into the FPR and then pressure out of the FPR. But...if its a cheap part then yeah maybe just replace it.
Old Jul 14, 2015 | 01:18 PM
02maxdd's Avatar
On the 5th gen there on the fuel rail correct?
Old Jul 14, 2015 | 02:21 PM
It's inside the fuel tank as part of the fuel filter housing. Accessible by removing the rear seats. Look at the FE section that foodmanry linked to. The process is rather simple. If you've already replaced the fuel filter than you've basically gone through the process already.
Old Jul 14, 2015 | 04:31 PM
02maxdd's Avatar
Do you know the part number
Old Jul 14, 2015 | 05:17 PM
226702Y500
There's also an o-ring and a clip I'd recommend replacing as well. Along with the larger o-ring for the whole assembly that's in the tank.
You can find them all here...
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Rage Maximus
Sep 3, 2015 12:26 PM
305head
Aug 26, 2015 09:03 PM
