Used ECM install
Used ECM install
Hello Gang:
2001 Maxima GLE 3 litre automatic with trac control. Replaced ECU/ECM with a best match from ebay. While waiting for delivery replaced cam sensor and crank sensor. Also new throttle body sensor and idle air valve (IAC). All assembled now and ready for the next step... starting it for the first time. not in possession of OBD II. I need a comprehensive response from a member that has done this before. Will I have to do a idle reset and a key reset? Went through many disappointments up to this point. One note of importance; when dismantle of (IAC) from throttle body anti freeze leaked. It wasn't till sometime after that i found out the line should have been pinched. Will this be a Quick resolve? Good advice welcomed, thank you in advance.
Which to do first
Thanks for the response. Did you start the engine prior to having the keys matched and drive the vehicle to the dealership or have it towed? I want to stick to a strict procedure. Just cant afford having another ECU fry up on me. A " procedure " is what I'm after the ECU is installed.
MaxLife17
Jun 27, 2019 01:37 PM
