knock sensor in 00 max - replace or no?
Old Oct 18, 2015 | 08:37 PM
cornholio's Avatar
so the upper intake manifold is off. should i go a bit further and replace the knock sensor while i'm here? been reading this thread:
https://maxima.org/forums/5th-genera...ck-sensor.html
and not sure if it's worth it to go the extra mile. i don't have any codes, but also don't want to dig this deep in the future. i already have a gasket set (ripped my uim gasket whoops lol), for a 15 year old car where random things are failing, would it be worth the added cost of the sensor and time to install? looks like fuel rails and lim need to be removed to make this happen. all input is appreciated, thanks gentlemen
Old Oct 18, 2015 | 10:43 PM
Child_uv_KoRn's Avatar
Bad *** Newb
It's not worth the money to me. I'd just bypass it if it goes bad.
You need to do the coolant bypass on the throttle body before your ECU goes poof.
Old Oct 21, 2015 | 09:06 AM
cornholio's Avatar
seems like i will ignore it then. thanks for the response
definitely plan on doing the coolant bypass while things are apart. i feel i already dodged that bullet once a year and a half ago when i had to replace iacv.
Old Oct 21, 2015 | 10:54 AM
maxiiiboy's Avatar
+1 !!!
And replace fuse #58 with 7.5A fuse; this note explains: https://drive.google.com/file/d/0B6O...1fNlF5QjQ/view .
PH98I30
Jan 9, 2025 08:08 AM
maxprivate
Nov 29, 2017 08:52 AM
MaxStock
Aug 12, 2015 08:33 AM
