What to look for when purchasing a 5gen
Old Oct 22, 2015 | 02:29 AM
ReMiXeDg's Avatar
HI all, So i am looking to purchase a 5gen maxima.
Whats the best year I should look at for a auto.
And what should i check when looking / inspecting the car that I am interested in?
Radiator support is in the front I should check under that right?
If I have around 3,000 to spend on a maxima what kind of maxi should I look into and whats the Ideal mileage i should look for / stay away from thanks.
Old Oct 22, 2015 | 03:23 AM
QueensMAX's Avatar
Like you said, check for rust.. bring a scanner and check for codes and see if all the monitors are good and ready.
rear calipers (check to see if seized)
radiator (see if the top is leaking)
radiator fans (flip on the AC make sure they both work)
If its the 3.5 check the exhaust for any soot which maybe an indication of oil burning.
Old Oct 22, 2015 | 04:53 AM
ReMiXeDg's Avatar
thanks for the reply. how can i check for rear calipers siezed. and also the exhaust check for smoke? or soot whats soot..
also one more question guessing by your username are you from queens ny? is so nice to see someone from there on here im not to far from there
Old Oct 22, 2015 | 07:21 AM
QueensMAX's Avatar
Yup in queens. Soot is caked up or oil residue in the exhaust pipe, which is an indication of oil burning. If you are looking for any maxima's or i30's, I can refer some good cars to you..MSG Me..
Old Oct 22, 2015 | 07:37 AM
mclasser's Avatar
5th gens are solid since they aren't prone to oil burning like the 5.5 gens. In either case, check for general stuff like rust, engine misses or stumbling, alignment, vibrations, rattles. Make sure the car doesn't pull to one side when braking -- seized caliper(s) if does. Do a long test drive, not just a quick spin around the block, in both the city and highway to check for engine and tranny overheating. Do a cold start yourself without having the owner/dealer already letting the car idle for you when you get there. You'll be surprised at the issues you can pick up when the car's cold that don't show up when it's warmed up. It's worth having a mechanic check out any car you're interested.
Old Oct 22, 2015 | 01:05 PM
ReMiXeDg's Avatar
Thanks for the reply . I'm from ridgewood queens. I'm going to hit you up in about a week or two when I'm ready and if anythin I can throw you a bone for looking out / helping and for your time thanks . My name is greg by the way.
Wow nissan guys are much better than honda games
CRizz
41
Jun 7, 2021 05:42 AM
FlaMark
Jan 8, 2016 07:21 AM
jerrod99_se-l
Aug 24, 2015 10:24 AM
xUNIxPanther
Aug 5, 2015 09:31 AM
