Car won't start
Dec 2, 2015 | 04:48 PM
Loss power on highway TCS and abs light
https://youtu.be/zBO40xz2wA8
Dec 2, 2015 | 08:07 PM
It sounds like the starter is engaging the flywheel but cannot crank the engine over. How is the battery? Have you tried jumper cables?
Dec 2, 2015 | 10:34 PM
Well this vid is after having the battery charged at autozone previously car loss power on highway replaced cam sensors got car to start but engine was knocking then it just died now eont crank starter is fearly new
Dec 3, 2015 | 12:16 AM
Engine is seized. If you have precats, you already have the cause. Proof will be if there's no oil in it.
Dec 5, 2015 | 06:52 PM
It seems like your starter/battery can't crank the engine. You got good advice in post #2 above. Adding to it:
  • Have you tried to get a boost? What happened?
  • In case you can't get a boost: The voltage on your battery should be at least 12.5V with the engine not running, and ~ 14.5V when running and charging. It should not drop below 10-10.5V when you are cranking. If it does, your battery is bad.
  • If the battery looks OK but you still can't crank, then the suspects are: Your starter, or the connections/ground between the starter and the battery.
Dec 6, 2015 | 07:25 AM
Quote: It seems like your starter/battery can't crank the engine. You got good advice in post #2 above. Adding to it:
Thank you will be trying to chk starter next.
Dec 6, 2015 | 08:25 AM
Put a socket on the main pulley bolt and see if the engine will turn manually. Just make sure it's in neutral and your ignition is off.
Dec 7, 2015 | 04:54 AM
[/U]QUOTE=Child_uv_KoRn;9084025]Engine is seized. If you have precats, you already have the cause. Proof will be if there's no oil in it.[/QUOTE]
Dec 7, 2015 | 04:29 PM
Quote: [/U]QUOTE=Child_uv_KoRn;9084025]Engine is seized. If you have precats, you already have the cause. Proof will be if there's no oil in it.
[/QUOTE]
That's exactly how a seized engine sounds if you try to start it. His symptoms fit perfectly, as well. That loud clunk is the starter engaging.
If it doesn't turn easily by hand, then it's seized.
It's not like I have experience with seized 3.5s or anything....
